COIL iconTheme
Moderator: agryson
1D_Inc
COIL iconTheme
Postby 1D_Inc » Wed Mar 06, 2019 10:52 am
This is thread about COIL FreeCAD icon theme - research about redesign FreeCAD icons in minimalistic style.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Wed Mar 06, 2019 10:54 am
Icon Slicer Script release - for test purposes and feedback.
https://github.com/formjune/1D_SVG_Tools
RCC files for testing with newer version of IconTheme addon
https://www.dropbox.com/s/wo0hsutk8glhx ... C.zip?dl=0
_____________________________________
Additional files
https://forum.freecadweb.org/viewtopic. ... 30#p292101
1D_Inc
Re: COIL iconTheme
Demo preview (Fullsize PNG, open in new window or save file to view in fullsize)
COIL ICON PACK v0.1 LA demo 06-03-2019.png (917.3 KiB) Viewed 5139 times
Re: COIL iconTheme
Postby Kunda1 » Wed Mar 06, 2019 11:55 am
Awesome Presentation and work!
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Wed Mar 06, 2019 12:12 pm
Thank you forr feedback)
Now we are working on reducing the color palette, trying to figure monochrome/ dark theme solutions, and programming SVG slicer to split BASE file to icons automatically.
Also - Simple icon theme
https://forum.freecadweb.org/viewtopic.php?f=22&t=18417
FC_COIL theme.png (81.4 KiB) Viewed 5115 times
triplus
Re: COIL iconTheme
Postby triplus » Fri Mar 08, 2019 10:36 pm
@1D_Inc
In the other thread i said around two weeks time needed on my side. But i went ahead and enabled temporary solution, for you to being able to proceed with your work without any mayor interrupts:
https://forum.freecadweb.org/viewtopic. ... 01#p292101
P.S. On Arch Linux rcc tool is a part of the qt5-base package.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Fri Mar 08, 2019 11:00 pm
@1D_Inc
Thank you)
But I'm a person that is pretty much far from compiling, I am linux user for about a month, I use it mostly for rendering)
Current solution is working nice for me - I can see enough to make design decisions.
Currently we are busy with slicer, I guess it will take also about a week.
Then I planning to work with color themes closer, as far as it will have much more sense, because of possible speed increase.
triplus
Re: COIL iconTheme
Postby triplus » Fri Mar 08, 2019 11:52 pm
Thank you)
You're welcome.
Sounds good. For now both options are still supported and use whatever you like. Any interested user can create such icon pack locally, by following the instructions. Likely, once you will try the procedure out, you should notice it's easier, when compared to rendering. ;)
P.S. Using this approach should enable you and other people to go beyond limitations of the previous approach:
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Sat Mar 09, 2019 11:34 am
Polyline icon redesign process, due to it's M (arc) function
I like first line there (ND, n and P shapes)
Also D3 is looking most clean of them, but it may be confused with kind a fillet action.
n shape (F1) has the same density as previous polyline icon, and it have no such issue.
A1 (ND shape) is my favorite one, but, indeed, it cannot be created with sketcher)
Don't know if it matters, previous version also had this issue all this time, but visually, like an icon, it worked well.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Sun Mar 10, 2019 1:22 pm
A1 was chosen for polyline icon.
Also, Zone icon redesign
