Building Libs for Windows Debug Version with VS2017/Qt5.12
Hi all,
i am still trying to compile FC from source with VS2017 in debug mode.
Compiling works and now it comes to run FC. When using the PySide wrapper to load PySide2 i get the following problem:
When WidgetFactory.cpp wants to loads the modules PySide2.QtCore,PySide2.QtGui,PySide2.QtWidgets, shiboken can load the modules and returns a valid PyObject in WidgetFactory.cpp line 445 (valid means not a null ptr). But in line 449 shiboken tries to get the types from the PyObject (Shiboken::Module::getTypes), but this returns a null pointer.
This happens also when loading PySide2.QtCore and PySide2.QtWidgets.
Does someone has an idea?
BR Manuel
BR Manuel
Re: Windows PySide2 / Shiboken / Qt5.12
Solved the Problem. It was a debug/release miss match while building pyside with python.exe and python_d.exe.
Fc starts now without any errors. But now I am facing the next problem.
I rename the topic to track all my experience building the debug libs.
Next problem:
When starting the draft GUI, the icons have no image. Or at least the snapping tool does not.
Running the Draft Tests fails with an access violation in the pivy wrapper.... Null Pointer...
Br Manuel
Next problem:
Br Manuel
Re: Building Libs for Windows Debug Version with VS2017/Qt5.12
Running the test probably fail because the whole Coin3d stuff does not work.
Right now i get the following error message when trying to create a new document:
Must have a current GL context when instantiating cc_glglue!! (Note: if you are using an old Mesa GL version, set the environment variable COIN_GL_NO_CURRENT_CONTEXT_CHECK to get around what may be a Mesa bug.)
It comes from gl.cpp from the coin source. I have already build coin with superglu but the same result.
Does someone know this issue on windows?
BR Manuel
PS: Running on Windows10 with the latest Nvidia Driver for a GTX-1080
BR Manuel
IMO this is caused by a different behaviour in Qt 5.12. I guess the only way is to test it with an older Qt version (e.g. Qt 5.9 still works) and for both versions debug through the Qt source code to find out what exactly is different. Maybe this way you can find out a workaround to make it working again.Running the test probably fail because the whole Coin3d stuff does not work.
FYI, several weeks ago I had tmp. access to a system where VS 2017 was installed and using Qt 5.12 I had the same problems. Switching back to Qt 5.9 did the trick. Unfortunately, I hadn't the chance to look deeper why Qt 5.12 is causing problems.
Thanks Werner for the hint. You save me a lot of debbuging time!
I will later try with the older qt version for now. If it works I can continue with all the other libs and later try to switch to Qt 5.12....
After digging around i found out that going back to an older qt version may a bad idea. PySide2 is official release with qt 5.11. Going back to Qt 5.9 brings some other difficulties. The building script just works with python 3.6....
After searching the internet how to get coin3d and qt 5.12 to work i just found a discussion (https://groups.google.com/forum/#!topic ... yP2qNN_Osw) the descriped option works to get the error a way. But like everything, one error is gone the next is there....
Now Qt throws the following error when creating a new document:
ASSERT failure in QVector<T>::operator[]: "index out of range", file c:\users\qt\work\qt\qtbase\include\qtcore\../../src/corelib/tools/qvector.h, line 433
I dont see any error in the fc source code.....
See my call stack: Now i am trying to get the qt source and debug symbols to go in the source code....
Maybe someone has an other idea?
wmayer, maybe?
BR Manuel
wmayer, maybe?
BR Manuel
Update:
Working with Teamviewer on my desktop pc just works fine! There is no problem to create a scene and add parts...
Seems that it is a opengl over rdp problem. I found couple of discussions in the internet about this....
BTW: In the past i have discovered that over remote desktop the rendering does not work so well....
Maybe some one can test this too and can tell us his/her experience...
Update:
I cant figure out why my python to coin binding does not work.
I use swig version 3.0.10.
It always throws an exception in python_d.dll after the call comes from swigpyrun.h in line 2484.
when creating
The exceptions comes from here:
I can reproduce this when running
Does someone can help me out?
My next step would be using an older swig version, any recommendation which version could work?
BR Manuel
inst = ((PyTypeObject*) data->newargs)->tp_new((PyTypeObject*) data->newargs, Py_None, Py_None);
SWIG_Python_NewShadowInstance(SwigPyClientData *data, PyObject *swig_this)
excess_args(PyObject *args, PyObject *kwds)
return PyTuple_GET_SIZE(args) ||
(kwds && PyDict_Check(kwds) && PyDict_GET_SIZE(kwds));
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
BR Manuel
Did you build pivy with the same swig version as you generated the file swigpyrun.h?
Yes, i have build pivy with same swig.
