PVS-Studio
PVS-Studio
PVS-Studio Analyzer - Static Code Analysis for C, C++, C# and Java
https://www.viva64.com/en/pvs-studio/
Technologies used in the PVS-Studio code analyzer for finding bugs and potential vulnerabilities
https://www.viva64.com/en/b/0592/
Free PVS-Studio for open source projects
https://www.viva64.com/en/b/0600/
Getting Started with the PVS-Studio Static Analyzer for Visual C++
https://www.viva64.com/en/b/0642/
Analysis of commits and pull requests in Travis CI, Buddy and AppVeyor using PVS-Studio
https://www.viva64.com/en/b/0679/
Static Analysis: From Getting Started to Integration
https://www.viva64.com/en/b/0753/
How to Get Nice Error Reports Using SARIF
https://www.viva64.com/en/b/0798/
How to write more reliable code - Egor Bredikhin - Meeting C++ 2018
https://www.youtube.com/watch?v=KpdSFZOQCl8
PVS-Studio in 2019
https://www.youtube.com/watch?v=FkfMGqxIR-I
Top 10 Bugs Found in C++ Projects in 2020
https://www.viva64.com/en/b/0784/
Intermodular analysis of C++ projects in PVS-Studio
https://pvs-studio.com/en/blog/posts/cpp/0851/
Why we need dynamic code analysis: the example of the PVS-Studio project
https://pvs-studio.com/en/blog/posts/cpp/0868/
Classification of PVS-Studio warnings according to OWASP Top 10 Web Application Security Risks
https://pvs-studio.com/en/pvs-studio/sast/owasptopten/
What's New in PVS-Studio in the Second Half of 2021
https://www.youtube.com/watch?v=dpPa3R3wFds
PVS-Studio: static code analysis technology
https://pvs-studio.com/en/blog/posts/0908/
PVS-Studio evolution: data flow analysis for related variables
https://pvs-studio.com/en/blog/posts/csharp/0942/
PVS-Studio's data flow analysis untangles more and more related variables
https://pvs-studio.com/en/blog/posts/csharp/0976/
Intermodular analysis of C and C++ projects in detail. Part 1
https://pvs-studio.com/en/blog/posts/cpp/0963/
Intermodular analysis of C and C++ projects in detail. Part 2
https://pvs-studio.com/en/blog/posts/cpp/0965/
What static analysis cannot find
https://pvs-studio.com/en/blog/posts/1037/
How static analysis works
https://pvs-studio.com/en/blog/posts/1048/
60 terrible tips for a C++ developer
https://pvs-studio.com/en/blog/posts/cpp/1053/
Common patterns of typos in programming
https://pvs-studio.com/en/blog/posts/cpp/1064/
Simple, yet easy-to-miss errors in code
https://pvs-studio.com/en/blog/posts/cpp/1068/
FreeCAD and undefined behavior in C++ code: meditation for developers
https://pvs-studio.com/en/blog/posts/cpp/1072/
New Year's Eve show: Top 10 errors in C and C++ projects in 2023
https://pvs-studio.com/en/blog/posts/cpp/1092/
Shall we check pointer for NULL before calling free function?
https://pvs-studio.com/en/blog/posts/cpp/1100/
OOP in real-life cases
https://pvs-studio.com/en/blog/posts/java/1103/
Why it is bad idea to check result of malloc call with assert
https://pvs-studio.com/en/blog/posts/cpp/1104/
Parable of null pointer for indolent C programmers
https://pvs-studio.com/en/blog/posts/cpp/1107/
How not to check array size in C++
https://pvs-studio.com/en/blog/posts/cpp/1112/
Static analyzer nudges you to write clean code
https://pvs-studio.com/en/blog/posts/cpp/1115/
A general post about the security and code quality tools https://forum.freecadweb.org/viewtopic. ... 02#p274069
PVS-Studio in 2019
Re: PVS-Studio
I have created an analysis of the FreeCAD code (build 0.18.15892) with PVS-Studio. The report is available in an html format to all developers that are interested to have a look at it...
As always, take care of the possible false positives with this reports, some discussions about that can also be found in the below links for the LibreOffice report...
Here are a few links to a similar report that was done for the LibreOffice
https://www.viva64.com/en/b/0586/
https://bugs.documentfoundation.org/sho ... ?id=120703
https://cgit.freedesktop.org/libreoffic ... grep&q=pvs
Re: PVS-Studio
In the recent weeks I was working from time to time on many of the reported issues. So far I have fixed a good amount of them and pushed the changes to the repository, some are in a local branch and will be pushed after the v0.18 release and still around 100 are left to be fixed.
At the moment there are only two issues with priority "High". These are:
TaskProjGroup.cpp:405 and TaskProjGroup.cpp:407
PVS is complaining about these two lines:
const char * TaskProjGroup::viewChkIndexToCStr(int index)
// Third Angle: FTL T FTRight
// L F Right Rear
// FBL B FBRight
// First Angle: FBRight B FBL
// Right F L Rear
// FTRight T FTL
assert (multiView != NULL);
bool thirdAngle = multiView->usedProjectionType().isValue("Third Angle");
switch(index) {
case 0: return (thirdAngle ? "FrontTopLeft" : "FrontBottomRight");
case 1: return (thirdAngle ? "Top" : "Bottom");
case 2: return (thirdAngle ? "FrontTopRight" : "FrontBottomLeft");
case 3: return (thirdAngle ? "Left" : "Right");
case 4: return (thirdAngle ? "Front" : "Front");
case 5: return (thirdAngle ? "Right" : "Left");
case 6: return (thirdAngle ? "Rear" : "Rear");
case 7: return (thirdAngle ? "FrontBottomLeft" : "FrontTopRight");
case 8: return (thirdAngle ? "Bottom" : "Top");
case 9: return (thirdAngle ? "FrontBottomRight" : "FrontTopLeft");
default: return NULL;
Is this on purpose that for the ? : operator in both cases the same value is returned or is it a copy-paste error?wandererfan wrote: ping
- wandererfan
Re: PVS-Studio
The code is functionally correct.wmayer wrote: ↑Sat Mar 09, 2019 12:13 pm PVS is complaining about these two lines:Code: Select all
Front and Rear views occupy the same position in both FirstAngle and ThirdAngle conventions. All the other views move between First and Third.
Re: PVS-Studio
OK, thanks for the clarification.
Re: PVS-Studio
Happy to hear that the report was useful... Both thumbs up for fixing the issues this fast!
Re: PVS-Studio
It found many issues other code checking tools didn't find. However, there are a lot of false-positives and you have to look at all issues very carefully to avoid to make any regressions.
Other detected issues are formal correct but when following the advices it could happen that it will break the code when changing something in the class interface. So, it's best not to touch the relevant code.
So far I presumably have fixed around 30% (maybe more) of all issues.
Re: PVS-Studio
At the moment there are left 15 issues I will have a look at. If you have some time then I will appreciate it if you can check the issues in CommandConstraints.cpp:4632, ..., with the description: Possible incorrect order of arguments passed to 'makeTangentToArcOfHyperbolaviaNewPoint' function: 'geom2' and 'geom1'.
Re: PVS-Studio
Thanks for letting me know this. Because you filter the false positives, I only see the good part of the tool.wmayer wrote: ↑Wed Mar 13, 2019 3:53 pmIt found many issues other code checking tools didn't find. However, there are a lot of false-positives and you have to look at all issues very carefully to avoid to make any regressions.
It is good that I am trying to learn form the good part too
