Detailed Preferences documentation available
Jee-Bee
Re: Detailed Preferences documentation available
Post by Jee-Bee »
wmayer wrote: Sat Mar 09, 2019 5:49 pm I don't know if $HOME also exists on macOS but it might be as it also has its roots in Unix.
Jee-Bee-MacBook:ASPFMA jee-bee$ $HOME
-bash: /Users/jee-bee: is a directory
I think so
uwestoehr
Post by uwestoehr »
wmayer wrote: Sat Mar 09, 2019 5:49 pm The directory where we put the user stuff is $HOME/.FreeCAD...
sgrogan wrote: Sat Mar 09, 2019 4:39 pm
Thanks, I added this info now.
wmayer wrote: Sat Mar 09, 2019 5:49 pm SMF = Simple Mesh Format. The link to the specs is here: http://people.sc.fsu.edu/~jburkardt/data/smf/smf.txt
Thanks, this is now in too.
Here is where to find the config directories: url=https://www.freecadweb.org/wiki/index.p ... rt_anymore
Re: Detailed preferences description
uwestoehr wrote: Sat Mar 09, 2019 3:46 pm
chrisb wrote: Sat Mar 09, 2019 8:12 am - The Expand-button inside of the table header is a bit cumbersome. I would prefer something which makes it clearer what is to be expected on expand, such as a heading "Settings" or "Available Settings".
I don't know what you mean exactly. I have just taken the foldable tables as they are also used in the Wikipedia. Could you give me a syntax example of how I should format the tables or an extra header line?
I mean something like the Contents section of wikipedia. It shows a header which collapses/expands a subsection. You may also have a look at the Macros recipes.
uwestoehr
Post by uwestoehr »
chrisb wrote: Sat Mar 09, 2019 11:43 pm I mean something like the Contents section of wikipedia. It shows a header which collapses/expands a subsection. You may also have a look at the Macros recipes.
The Wiki page uses already the same Content as the Wikipedia. Concerning the collapsible content in the page Macros recipes I played a bit. The point is that I prefer a table Therefore I tried to put it into a collapsed <div>:
div class="toccolours mw-collapsible mw-collapsed">
<div class="mw-collapsible-content">
{| class="wikitable float-right mw-collapsible mw-uncollapsed"
!style="width: 33%;"|Name
!style="width: 66%;"|Description
| {{MenuCommand|Change language}}
| Select the language of FreeCAD's user interface
</div>
</div>
But I prefer how it looks directly with the collapsible tables. I also don't want to reinvent the wheel - the Wikipedia defined collapsible tables and uses it heavily. Obviously the readers accept that style and so I think our users will accept that we use the same collapsible tables as the Wikipedia.
I didn't mean to change the contents, it was only an expand/collapse example. I was rather thinking of something like https://de.wikipedia.org/wiki/Citroen_C ... sche_Daten where you see a meaningful headline which can be expanded. Like the Macros recipes the headline tells already what can be expected on expand.
uwestoehr wrote: Sun Mar 10, 2019 12:35 am I also don't want to reinvent the wheel - the Wikipedia defined collapsible tables and uses it heavily.
That's understandable and interesting. Could you please give me a pointer to such a page? I am probably looking in the wrong corner of the almost borderless wikipedia.
uwestoehr
Post by uwestoehr »
chrisb wrote: Sun Mar 10, 2019 8:03 am I was rather thinking of something like https://de.wikipedia.org/wiki/Citroen_C ... sche_Daten where you see a meaningful headline which can be expanded.
The FC Wiki doesn't have a class "BoxenVerschmelzen" defined that is used in the Wiki page you mentioned.
I played now a bit and the best outcome so fare is this:
https://www.freecadweb.org/wiki/Prefere ... l_Settings
Nevertheless I like it more when the header line of the table is already shown so that readers get the info what will be expanded.
I don't want to spent too much time on the formatting. I think the Preferences page is now better than before and contains necessary info to use FC in a more powerful way. If readers complain that the exandable tables don't look good, we could become active and e.g. define a "BoxenVerschmelzen" class.
uwestoehr wrote: Sun Mar 10, 2019 12:22 pm I don't want to spent too much time on the formatting.
Fully agreed.
uwestoehr
Post by uwestoehr »
chrisb wrote: Sun Mar 10, 2019 8:03 am Could you please give me a pointer to such a page? I am probably looking in the wrong corner of the almost borderless wikipedia.
I just saw such a table in this page: https://en.wikipedia.org/wiki/Ethiopian ... Passengers
Thanks.
