Sketcher tutorial
HarryGeier
Re: Sketcher tutorial
Postby HarryGeier » Tue Feb 26, 2019 11:56 am
Hannu wrote:
Mon Feb 25, 2019 9:01 pm
Part of that might be the fact that coincident constarints do not show up in the sketch, the same way that others do (with a symbol).
I agree that it is sometimes hinderly, even though it´s less clutter. There is a similar small issue that sometimes makes me mad:
If , especially pointoncurve is there twice, you can´t select either of the overlaying icons , you allway have to use the constraint finder. Maybe some idea for a 0.19 wish to overwork constraint display in sketcher a little.
Gray Area
Postby Gray Area » Wed Mar 06, 2019 9:41 pm
I downloaded this tutorial the other day.
I give my thanks to chrisb and everyone who has worked with him in the making of this tutorial.
Gray Area
onesz
Postby onesz » Thu Mar 14, 2019 6:58 pm
@chrisb
Thank you for your effort for this tutorial.
It is really helpful.
Is it free to use and translate?
openBrain
Postby openBrain » Sat Mar 16, 2019 6:03 pm
@chrisb, tutorial in chapter about Point element tells :
The point serves only as construction geometry. It is not possible to construct a sketch containing only a point as real geometry. (This would be desirable for Lofts which end in a single point.) This holds for the current version of 0.18, it might change in the future.
While it's correct with PartDesign AdditiveLoft, it seems possible with the Part Loft function.
I never tested myself, but it could be worth having a sidenote about that. ;)
Postby chrisb » Sat Mar 16, 2019 9:28 pm
The tutorial is about sketcher. It is not possible to use such a point in Part or PartDesign Loft.
openBrain
Postby openBrain » Sat Mar 16, 2019 10:10 pm
Indeed. I just tested and you're definitely right. :)
I've been fooled by the wiki description that doesn't precise that only Draft point is allowed. ;)
Postby chrisb » Sun Mar 17, 2019 6:25 am
I added a hint to Draft anyway, because that's the only way to to add a singular point. All other 2D stuff can be done in sketcher - and from my personal POV much better.
bejant
Postby bejant » Sun Mar 17, 2019 1:11 pm
With Loft and Sweep tools added to Part Design, I think a Sketch containing only a Point should be made valid for use in Part Design Loft and Sweep, if that is possible.
Jee-Bee
Postby Jee-Bee » Sun Mar 17, 2019 1:44 pm
Some time ago there was a obelisk challenge? see https://forum.freecadweb.org/viewtopic.php?p=189531
The result of that was the same that the point is only a helper object but don't have a physical meaning. see also https://forum.freecadweb.org/viewtopic.php?t=24203
I maybe we have to add a feature request to it...
openBrain
Postby openBrain » Sun Mar 17, 2019 3:11 pm
It should be thought about potential impacts. For me considering a point as a virtual geometry is meaningful.
As an exemple, I wouldn't that solver become less powerful because of that.
And honestly, using a point or a 1nm (nanometer) circle for lofting doesn't change things a lot. ;)
