Traction engine
un1corn
Traction engine
Post by un1corn »
Designed by Julian DeWaal, other images available........
JD 4.JPG (259.94 KiB) Viewed 4536 times
JD 9.JPG (466.95 KiB) Viewed 4536 times
JD 7.JPG (399.23 KiB) Viewed 4536 times
JD 3.JPG (396.36 KiB) Viewed 4536 times
HarryGeier
Re: Traction engine
Post by HarryGeier »
Impressive work !
Congrats...
EvilSpirit
Re: Traction engine
Post by EvilSpirit »
Can you show superheater in details?
un1corn
Re: Traction engine
Post by un1corn »
Does not have a 'Super heater' per se, so have posted the boiler assembly FYI, hope it helps.
Boiler assy.JPG (158.7 KiB) Viewed 4069 times
EvilSpirit
Re: Traction engine
Such simple? I excepted to see something like many pipes with huge area of surface for better heat exchange.
herbk
Re: Traction engine
Post by herbk »
EvilSpirit wrote: Tue Mar 26, 2019 12:32 pm Such simple? I excepted to see something like many pipes with huge area of surface for better heat exchange.
This technique has come only several years later... ;) ;)
Gruß Herbert
GeneFC
Re: Traction engine
Post by GeneFC »
Julius de Waal (not Julian) is a very prolific designer who has created hundreds of Solidworks models of varying complexity. This model, the Julian Traction Engine, is intentionally designed to be quite simple. Some others, such as his Allchin design, are full featured and quite complex. Many designs are not original, but instead are CAD versions of older paper designs. The Julian is loosely based on a Case prototype, but it basically freelance.
The point of un1corn's work and posting here is to showcase the use of FreeCAD to make the same models that have been made in Solidworks.
If you are interested in more designs from Julius de Waal the most complete location can be found at
http://www.vapeuretmodelesavapeur.com/i ... index.html
[Edit -- I noticed that this is my 1000th post in the forum.] 8-)
Gene
Re: Traction engine
Congratulations Millenium-Gene. I always highly appreciate your contributions! Spot on for on- and off-topics. If I would ever had programmed FORTRAN I would have said: continue!
Jee-Bee
Re: Traction engine
Post by Jee-Bee »
chrisb wrote: Wed Mar 27, 2019 4:38 pm Congratulations Millenium-Gene. I always highly appreciate your contributions! Spot on for on- and off-topics. If I would ever had programmed FORTRAN I would have said: continue!
If you had programmed python you could say that as well
https://www.tutorialspoint.com/python/p ... ontrol.htm
un1corn
Re: Traction engine
Post by un1corn »
Apologies to Julius for mispronouncing and spelling his name.
In fact I have a passion for steam driven vehicles and machinery, and NO I am not living in the past, these engines have a character and strength of their own.
