Sheet Metal Workbench
Re: Sheet Metal Workbench
I think there is no use in repairing this model. I recommend to keep the sketches and remodel it in a current 0.18 version.
Tomas
Post by Tomas »
chrisb wrote: Tue Mar 19, 2019 10:47 am I think there is no use in repairing this model. I recommend to keep the sketches and remodel it in a current 0.18 version.
Hi Chris,
Ok, thanks for your effort.
BR
Tomas
m.cavallerin
Post by m.cavallerin »
Hi
I just installed the master 0.18 version freecad:
OS: Linux Mint 19
Version: 0.18.
Python version: 3.6.7
Qt version: 5.9.5
ad now the "create a sheet metal wall from sketch" do not highlist with a selected sketch. Can someone helps me?
Post by NormandC »
Hello,
m.cavallerin wrote: Thu Apr 04, 2019 9:41 pm ad now the "create a sheet metal wall from sketch" do not highlist with a selected sketch. Can someone helps me?
I didn't even know the tool had been added, (I remember the discussion about splitting it from the Wall tool months ago), thanks for the info!
You seem to be using the release from the freecad-stable PPA, correct? I confirm that the tool is inactive with Python3, but it works in Python2.
To switch your FreeCAD to use Python2, make sure that the freecad-python2 package is installed, then in a terminal paste:
sudo update-alternatives --config freecad
This will bring a choice to toggle between freecad-pyhon2 and freecad-python3.
shaise wrote:ping
Can you have a look? Most 0.18 installers are being built with Python3, the freecad PPA on Ubuntu is the only installation that can easily be switched between Python 2 and 3.
Thanks!
m.cavallerin
hi and thx, that's the output from the terminal, in any case do you think there will be un update to python3?
 → sudo update-alternatives --config freecad
There is only one alternative in link group freecad (providing /usr/bin/freecad): /usr/lib/freecad/bin/freecad-python3
Nothing to configure.
Post by NormandC »
NormandC wrote: Fri Apr 05, 2019 4:36 am To switch your FreeCAD to use Python2, make sure that the freecad-python2 package is installed
m.cavallerin wrote: Fri Apr 05, 2019 4:03 pm do you think there will be un update to python3?
I'm not the developer of the Sheet Metal workbench, how could I possibly know?
m.cavallerin
Thx for the kindness.
Cheers
Michele
m.cavallerin
efyx wrote: Tue Oct 04, 2016 6:56 am ...
https://www.youtube.com/watch?v=eSfqk-n9iIs <-- from solid to sheetmetal
Hi according to this video I was able to obtain something similar:
https://www.youtube.com/watch?v=0wgsRLcy6nI
Cheers
easyw-fc
Post by easyw-fc »
m.cavallerin wrote: Fri Apr 05, 2019 5:40 pm ...
Cheers
Michele
It seems it should be patched
https://github.com/shaise/FreeCAD_SheetMetal/pull/64
m.cavallerin
easyw-fc wrote: Fri Apr 05, 2019 6:12 pm
Cheers
Michele
I do confirm.
thanks
