[paullee@localhost Temp_Download]$ ./FreeCAD_0.19
FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64.AppImage FreeCAD_0.19-16502-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
FreeCAD_0.19-16475-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage FreeCAD_0.19-16540-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16475-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAarcUwb
/tmp/.mount_FreeCAarcUwb/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16502-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCA0GG8Jb
/tmp/.mount_FreeCA0GG8Jb/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16540-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAQZDRvN
/tmp/.mount_FreeCAQZDRvN/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
It would be nice if anyone fedora-user seeing this problem can test if the same is happening with freecad installed via conda. Else we can't do much about it.
The 'native' 0.18 Fedora package has oce which I found problematic and I had turned to AppImage for quite sometime (despite some other fallback I had not had time to overcome) to run FC. Would have no alternative if AppImage no longer run.
P.S. We could add a note for Fedora users or try bundling libnsl in the AppImage in the future.
Oh Thanks @Triplus
Very basic problem and solution indeed!
Not thought of it is an 'external library' missing - Long time not trying to maintain a linux system (still running a Scientific Linux 6.x for no use) that lost the sense of searching external library dependency
And FC runs!
... though the interface becomes slightly uglier ?
Screenshot from 2019-05-04 08-49-25.png (175.58 KiB) Viewed 3206 times
paullee wrote: ↑Fri May 03, 2019 3:25 pm
FreeCAD 0.18.1 is provided as a flatpak. It runs well on Ubuntu, as I assume it would on fedora. I don't use IfcOpenShell though.
