check your CMakeCache.txt file you should turn on python 3
//Use Python V3
USE_PY_3:BOOL=ON
//Use Python V3
USE_PY_3:BOOL=ON
Thanks for the tip, but no joy. A complete clean new clone of the repo, used cmake-gui and turned on the USE_PY_3, turned off the BUILD_CXX_LIB and again, it builds with and installs in python2.7. Like I said, it shouldn't be this hard.nemesis wrote: ↑Thu May 02, 2019 5:30 pmhi,
check your CMakeCache.txt file you should turn on python 3Code: Select all
//Use Python V3 USE_PY_3:BOOL=ON
Yep
OS: Debian GNU/Linux buster/sid (KDE//usr/share/xsessions/plasma)
Version: 0.19.16540 (Git) AppImage
Hash: 554985dede771f9a6694baba2372cc60db86f17b
Python version: 3.7.1
Qt version: 5.6.2
Locale: French/France (fr_FR)
If you're feeling brave, you could install sudo apt install virt-manager and try testing things inside a VM which would let you keep your stable system intact while still letting you try new features.
