[Solved] AppImage after 0.19_pre 16291 - - No longer run in Fedora 29
paullee
Postby paullee » Thu May 02, 2019 10:56 pm
Hi, trying to see if patch was applied and bug fixed in latest 0.19_pre and find the captioned
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19
FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64.AppImage        FreeCAD_0.19-16502-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
FreeCAD_0.19-16475-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage  FreeCAD_0.19-16540-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16475-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAarcUwb
/tmp/.mount_FreeCAarcUwb/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16502-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCA0GG8Jb
/tmp/.mount_FreeCA0GG8Jb/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
[paullee@localhost Temp_Download]$ ./FreeCAD_0.19-16540-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAQZDRvN
/tmp/.mount_FreeCAQZDRvN/usr/bin/FreeCAD: error while loading shared libraries: libnsl.so.1: cannot open shared object file: No such file or directory
looo
Re: AppImage after 0.19_pre 16291 - - No longer run in Fedora 29
Postby looo » Fri May 03, 2019 4:54 am
It would be nice if anyone fedora-user seeing this problem can test if the same is happening with freecad installed via conda. Else we can't do much about it.
paullee
Postby paullee » Fri May 03, 2019 3:25 pm
Hmmm, anything I can do to help debugging?
The 'native' 0.18 Fedora package has oce which I found problematic and I had turned to AppImage for quite sometime (despite some other fallback I had not had time to overcome) to run FC. Would have no alternative if AppImage no longer run.
Thanks.
looo
Postby looo » Fri May 03, 2019 7:21 pm
This seems to be a new system dependency (py37 / new-toolchain) (although it is also shipped within the bundle.)
Maybe you can try to install the corresponding library. For ubuntu it's included in the package libc.
triplus
Postby triplus » Fri May 03, 2019 9:01 pm
Hi @paullee
Fedora 28 and up decided to not provide libnsl by default anymore. You should be able to resolve your problem by installing:
sudo dnf install libnsl
P.S. We could add a note for Fedora users or try bundling libnsl in the AppImage in the future.
paullee
Postby paullee » Sat May 04, 2019 12:56 am
Hi @paullee
Oh Thanks @Triplus
Very basic problem and solution indeed!
Not thought of it is an 'external library' missing - Long time not trying to maintain a linux system (still running a Scientific Linux 6.x for no use) that lost the sense of searching external library dependency :oops:
And FC runs!
... though the interface becomes slightly uglier ? :)
Screenshot from 2019-05-04 08-49-25.png (175.58 KiB) Viewed 881 times
looo
Re: [Solved] AppImage after 0.19_pre 16291 - - No longer run in Fedora 29
Postby looo » Sat May 04, 2019 7:19 am
Actually it's bundled in the 0.19 appimages, but not used...
paullee
Postby paullee » Sat May 04, 2019 2:26 pm
Seems more problems though it runs.... it can't find the IfcOpenShell previous AppImage can :(
And dialog boxes do look old-fashioned.
Screenshot from 2019-05-04 22-19-01.png (46.34 KiB) Viewed 825 times
Screenshot from 2019-05-04 22-17-02.png (47.4 KiB) Viewed 825 times
Postby NormandC » Sat May 04, 2019 4:26 pm
FreeCAD 0.18.1 is provided as a flatpak. It runs well on Ubuntu, as I assume it would on fedora. I don't use IfcOpenShell though.
https://forum.freecadweb.org/viewtopic.php?f=10&t=30368
https://flathub.org/apps/details/org.freecadweb.FreeCAD
looo
Postby looo » Sat May 04, 2019 5:18 pm
There are also other interested in an compatible ifc library for conda-forge. Maybe you can try to create a staged-recipe for this library:
https://conda-forge.org/docs/maintainer ... or-recipes
https://github.com/IfcOpenShell/IfcOpen ... .6.0/conda
If more people would work on conda-packages for freecad this would be a nice cross platform solution...
