Sorry, but this is beyond my English, I don't understand
Here are the links for 15310 and 15525.
Thanks for the binary, I will post 15310.
### MacOSX
Binary developer builds (no compiling necessary) are available. Download the highest revision of the .dmg
I guess 15310 was done with brew.
I would provide both versions.
Currently we provide two versions for MacOS:
- 0.18.15310 is slightly outdated compared to the official release, but runs very stable. We recommend to use this version, unless you want to use some functions not included here.
- 0.18.16110 is the official release version. However, this version crashes on some MacOS systems unexpectedly. If you use this version, save often!
Version 0.18.15310 is slightly outdated compared to the official release, but runs very stable. We recommend to use this version, because the official version may crash unexpectedly.
OK, therefore it's likely safe to assume Qt 5.6.2 Conda package, by itself, isn't the main problem here. I made a small change and first i guess @chrisb should test if the latest FreeCAD 0.18/0.19 .dmg from releases page still crash as often on his side or not, after we can discuss this further.
I'm ready to test. Any idea when it will be available?
