If I use version 12.1.2. The boost library cannot found. So I use 11.11.apeltauer wrote: ↑Thu May 09, 2019 6:34 amIn your pic i can see that your are using the libpack version 11.11. Any reason why not switching to the new one, version 12.1.2?tak wrote: ↑Thu May 09, 2019 5:51 amI got another problem now.
When check for medfile (libmed and libmedc), there is a error 'Unknown CMake command "ctest_empty_binary_directory".'
I checked the config in MEDFILE. "MEDFILE_F_LIBRARIES" not found and "MEDFILE_ROOT_DIR" is nothing. Are there something wrong?
https://imgur.com/r8ayh6E
