Seeing an up-tick in reports on the tracker and forum about users encountering UI issues due to their graphics card drivers. Is there a way we can add (and a consensus for adding) graphic card driver info to the About FreeCAD widget ?
Edit:
Maybe perhaps going so far as to give the user a heads-up that their specific graphics card may need an update due to 'known issues' they may encounter with said card ?
Discussion: adding graphics driver to 'About FreeCAD' output?
Re: Discussion: adding graphics driver to 'About FreeCAD' output?
Could be interesting. ATM the only way I can think about is to use the GL functions of Qt calling "glGetString(GL_RENDERER)".
It still has some limitations (Qt > 5.3 & use of openGL), and I don't know in which extent it works with all OS and/or GFX card.
- roerich_64
Will it be necessary to collect the problems first?
Can one already say exactly what the problem is to be recognized?
I have no problem with FC buildet with PY2.
When i will select one 'structure' or more 'structures' with a rectangle in a sketch on PY2 no problem.
but with PY3:
OS: Windows 7
Version: 0.19.16274 (Git)
Hash: 7c760259a389b38b76da78e4f6e1f9be66714842
Python version: 2.7.14
OCC version: 7.2.0
but with PY3:
OS: Windows 7
Version: 0.19.16267 (Git)
Hash: ddb335cfe057336f1958d68126bb0471328d735c
Python version: 3.6.6
Qt version: 5.6.2
Die Liebe wird siegen, denn sie ist unzerstörbar
I think having that info would be helpful for several things like:
- Speed up forum help (less messages asking info) when problem seems graphics/rendering card.
- To have history about user's graphics card distribution so identify problems in advance when software versions change or hardware support will be drop.
(Small subset of FreeCAD forum users, could be bigger is asking for user consent automatic report) - Extract a list of, for example "hardware tested or supported" to complement know issues.
- Cross platform implementation to query the different Operating Systems.
