There could be a button that appears when you hover over a joint like this and it lets you toggle the joint type!
Some inspiration for the workflow here: https://youtu.be/FWskGKAi-wk?t=87
Let's just do first things first, ok? To have tools that are able to automatically build a joint would be really nice, and I hope we get there one day but we have more basic ground to cover before thinking about this.Artis wrote: ↑Wed May 15, 2019 10:22 amThere could be a button that appears when you hover over a joint like this and it lets you toggle the joint type!
This is a good example of what we can do in FreeCAD Furniture workbench.Artis wrote: ↑Wed May 15, 2019 10:22 amThere could be a button that appears when you hover over a joint like this and it lets you toggle the joint type!
What's your vision? What tools do you think we can implement first?
I think we should implement first the basics as I've already said in this post.
Take care of your health first, and when you're better come to help us.
Yes, a nice approach for a good work-flow. The Fusion360 it is more accessible than other PRO level software's like TopSolid or SolidWorks with SWood, so a good start to study something we can adapt to FreeCAD.
Just thinking in advance here, once this workbench gets off the ground (which will be exciting) there needs to be some thought put in to this request b cause most likely we want to make this WB available via the FreeCAD-addons repo.
