[implemented] [PartDesign] Fix missing expression binding in primitives placement dialog
I think the dialog for additive/subtractive geometries has a bug:
- open the attached file. You can see that the radius of both spheres is set to the value in the spreadsheet
- now edit the subtractive or additive sphere
- in the appearing dialog you can change the radius. Do this by using the spin buttons.
result: the dialog shows you the value you set, e.g. 12mm. But after finishing the dialog the radius is correctly the one of the spreadsheet.
I think the fix is that the radius value field in the editing dialog gets the formula button as available e.g. for the attachment position fields:
- sphere-dialog-bug.FCStd
- file to reproduce
- (21.35 KiB) Downloaded 36 times
Re: additive/substractive primitives dialog bug
Yep, this missing ability is known and listed by chrisb in this thread
What I don't know is if he still wants to create a ticket before end of 0.19 release. Let's ask :
Wow your memory is amazing! I commented in ChrisB's thread as well. Since nobody reacted to ChrisB's post I gues the devs are simply not aware of it. So as it is straight forwards. I can act and open a bug report. I'll wait for Chris.openBrain wrote: ↑Fri May 17, 2019 5:15 pm Yep, this missing ability is known and listed by chrisb in this thread
I think chrisb's idea to first merge all places where expressions are missing, then open only one ticket, is the way to go.
Hi guys, thanks for waiting. I will recheck after DeepSOIC's comment and then open a ticket with improved specification for placement expressions.
This is fixed with PR: https://github.com/FreeCAD/FreeCAD/pull/3225
If I see it right, you fixed all of these: https://forum.freecadweb.org/viewtopic.php?f=3&t=33817.
Thanks!
Thanks!
No, only the 2nd bullet of the OP list of your thread is fixed. Could you strike it ?chrisb wrote: ↑Sat Mar 21, 2020 9:47 am If I see it right, you fixed all of these: https://forum.freecadweb.org/viewtopic.php?f=3&t=33817.
Thanks!
Basically what @uwestoehr pointed in the picture in the OP of this thread.
Good job. However would it be possible that you amend the commit message so :uwestoehr wrote: ↑Sat Mar 21, 2020 4:18 am This is fixed with PR: https://github.com/FreeCAD/FreeCAD/pull/3225
- It is a bit self-explanatory. Something like "[PartDesign] Fix missing expression binding in PartDesign primitives placement dialog"
- Change links to ticket so it conforms to what Source Integration expects. Something like "Partially fixing bug #3981"
Striking is done. I was mislead, by the plethora of changes and didn't realize that the 2nd bullet described multiple missing expression awarenesses.
Thanks nevertheless to Uwe.
