Windmill project
Re: Windmill project
Postby chrisb » Mon May 20, 2019 3:46 pm
Boneshaker wrote:
Mon May 20, 2019 3:09 pm
Maybe we make a monthly FreeCAD challenge in the showcase forum to build a library of more complex examples.
:+1:
bejant
Postby bejant » Wed May 22, 2019 3:26 am
I was curious about your way of modelling this.
I haven't finished but here's where I left off. The .pdf lists shows the Spreadsheet cells near the corresponding dimension but it is incomplete, it was done before I knew how the finished model was supposed to look, and if I were to do it again I'd only reference a few values from a Spreadsheet (as it is now I think it is more confusing than practical).
WindSculptureParts(1).pdf
(863.4 KiB) Downloaded 27 times
20190517a-Base_Drw.FCStd
(144.74 KiB) Downloaded 17 times
OS: Ubuntu 18.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
blue and strike-through = edit for better wording.
Postby chrisb » Wed May 22, 2019 6:04 am
The pdf seems to be damaged. Can anyone else open it?
UR_
Postby UR_ » Wed May 22, 2019 6:13 am
It's not a .pdf file, it's a .ps file. So please rename it. ;)
Annotation 2019-05-22 080936.png (62.13 KiB) Viewed 392 times
kisolre
Postby kisolre » Wed May 22, 2019 6:18 am
Probably attached the wrong file? " The .pdf lists the Spreadsheet cells..."
NCCALCADA
Postby NCCALCADA » Wed May 22, 2019 11:58 am
Here's my take on this little challenge.
I have read that it's really something and not a weird design for a wind turbine only after completing it:)
Made in 1h04min
windturbine.FCStd
(203.95 KiB) Downloaded 15 times
bejant
Postby bejant » Wed May 22, 2019 12:25 pm
Sorry, I did save it as a .pdf, and it opens and looks fine for me using Document Viewer (Evince) on Ubuntu 18.04 as shown in the image UR_ posted, but I don;t know how to fix it. I made the annotations and saved it using flpsed (which I hadn't used before) but I don't think I can save it any differently...
Edit: I'll try again later using Okular, which (I think) worked for me here before.
meme2704
Postby meme2704 » Wed May 22, 2019 12:45 pm
Made in 1h04min
Yes, but Bonshaker showed us that there was a perching cat :lol:
bejant
Postby bejant » Thu May 23, 2019 2:42 am
Maybe this attached pdf is better? I only did the first page and it should look like this:
If it looks ok then I'll add the cell notes to the other pages.
2019022a-WindSculptureParts (1).pdf
(399.72 KiB) Downloaded 17 times
kisolre
Postby kisolre » Thu May 23, 2019 6:02 am
Which one is the 12mm hole offset? Also I did not understand what is that 5mm dimension (B18 in your image)?
