[Solved] FEM doesn't work anymore
ElMastro
Post by ElMastro »
Good morning,
I've used Freecad for some years, but suddenly I realized I can't make the FEM module work anymore.
My version is
OS: ArchBang Linux
Version: 0.18.16117 (Git)
Branch: makepkg
Python version: 3.7.3
Qt version: 5.12.3
Locale: Italian/Italy (it_IT)
I tried to make a tutorial of the FEM on https://www.freecadweb.org/wiki/FEM_tutorial/it
First thing it doesn't show any window,and hitting Mesh> Mesh from shape by Gmsh it build it, but on the shell the output is
  File "/usr/lib/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py", line 72, in setEdit
    taskd = _TaskPanelFemMeshGmsh(self.Object)
  File "/usr/lib/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMeshGmsh.py", line 222, in __init__
    QtCore.QObject.connect(self.form.if_max, QtCore.SIGNAL("valueChanged(Base::Quantity)"), self.max_changed)
<class 'AttributeError'>: 'PySide2.QtWidgets.QWidget' object has no attribute 'if_max'
I add the force and the constraint, but when I add The Material, again from the shell it says
  File "/usr/lib/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 71, in setEdit
    taskd = _TaskPanelFemMaterial(self.Object)
  File "/usr/lib/freecad/Mod/Fem/femguiobjects/_ViewProviderFemMaterial.py", line 119, in __init__
    QtCore.QObject.connect(self.parameterWidget.cb_materials, QtCore.SIGNAL("activated(int)"), self.choose_material)
<class 'AttributeError'>: 'PySide2.QtWidgets.QWidget' object has no attribute 'cb_materials'
Active Task Dialog found! Please close this one before opening  a new one!
And doesn't make me change the Material showing a warning (Active Task Dialog found! Please close this one before opening a new one).
I recompiled it, but nothing seems wrong with the installation (also other modules works perfectly), I searched in the forum but I couldn't find anything similar. For reference, my gmsh verso is
gmsh -info
Version       : 4.2.3
License       : GNU General Public License
Build OS      : Linux64
Build date    : 20190407
Build host    : archbang
Build options : 64Bit ALGLIB Ann Bamg Blas Blossom Cairo DIntegration Dlopen DomHex Fltk GMP Gmm Hxt Hxt3D Jpeg Kbipack Lapack LinuxJoystick MathEx Med Mesh Metis Mmg3d Mpeg NativeFileChooser Netgen ONELAB ONELABMetamodel OpenCASCADE OpenCASCADE-CAF OpenGL OptHom Parser Plugins Png Post QuadTri Solver TetGen/BR Voro++ Zlib
FLTK version  : 1.3.5
OCC version   : 7.3.0
MED version   : 4.0.0
Web site      : http://gmsh.info
Issue tracker : https://gitlab.onelab.info/gmsh/gmsh/issues
and calculix and netgen are working.
Any suggestions?
Reason: fixed title
Re: FEM doesn't work anymore
Post by bernd »
ElMastro wrote: Mon May 27, 2019 10:13 am Good morning,
OK, there is at least on positve in this problem ... you joined the FreeCAD community :D Welcome to FreeCAD forum ...
ElMastro wrote: Mon May 27, 2019 10:13 am Version: 0.18.16117 (Git)
I can not reporduce it on Windows 0.18.16117
ElMastro wrote: Mon May 27, 2019 10:13 am I recompiled it, but nothing seems wrong with the installation (also other modules works perfectly),
does it mean you have the same porblem on a self compiled FreeCAD 0.18.16117 ? If yes would it be possible to write step by step what you have done? Something like start FreeCAD, make a box ... or provide some Python code to reproduce this. We had something similar in german forum, but I have not been able to reprocuce the problem.
ElMastro wrote: Mon May 27, 2019 10:13 am I add the force and the constraint, but when I add The Material, again from the shell it says
This is a follow up from the former problem. The mesh object is still in edit mode with an open task panel (which is not open due to the problem we do not know yet.) Try to finish the edit mode for the gmsh mesh object. right click on the obj. finish edit mode. The other workaround would be to savet the file and restart FreeCAD.
ElMastro
Post by ElMastro »
Thanks for the welcome :)
Yes, my copy is self compile, the script used is here https://aur.archlinux.org/cgit/aur.git/ ... ?h=freecad
What I do is this:
  • start Freecad
  • build a box
  • switch to FEM module
  • build an Analysis pressing the button
(nothing seems strange until this)[/list]
  • Mesh > Mesh from shape by Gmsh
When I do the mesh, this is what I see
https://ibb.co/BBr5KZC (can't upload the image with the code)
That is different from when I could use it, but it may depend on the fact that several version has passed.
  • change the resolution of the mesh to 0.1 mm (cube is small, 1 mm of height/lenght/depth)
  • click OK
Now the program complains with
The mesh has been generated, and it is invisible. However when I click on it it doesn't appair. I search on the internet but solutions seems to be for netgen meshes.
If I click on information it says
========================== Dump contents of mesh ==========================
1) Total number of nodes:      	0
2) Total number of edges:      	0
3) Total number of faces:      	0
4) Total number of polygons:   	0
5) Total number of volumes:    	0
6) Total number of polyhedrons:	0
7) Total number of linear edges:	0
8) Total number of linear faces:	0
9) Total number of linear volumes:	0
10) Total number of quadratic edges:	0
11) Total number of quadratic faces:	0
12) Total number of quadratic volumes:	0
I tried to check if using gmsh/netgen outside freecad works, but as I import the mesh it si not bound on the part, and so I couldn't do the FEM so far
Post by bernd »
very very strange. IMHO it seams the widget is not found or somehow broken.
Do you use a path with special character? Do you run from build directory or do you install FreeCAD?
I may try to breake it for me to, I got some ideas what could caus this. I will come back ...
ElMastro wrote: Tue May 28, 2019 9:59 am I tried to check if using gmsh/netgen outside freecad works, but as I import the mesh it si not bound on the part, and so I couldn't do the FEM so far
you do not need to bound it to the part.
- export the part as brep
- mesh with external mesher
- export the mesh to unv
- import unv mesh into FreeCAD
- move mesh object inside Analysis
- run analysis
I you would like to have changes on the mesh, just remesh with external mesher, export, import and exchange the mesh object in FreeCAD analysis by drag and drop.
Post by bernd »
Ha you are on Arch Linux ... :shock: There was some problem, but different, but Arch problems https://forum.freecadweb.org/viewtopic. ... 40#p309083
ElMastro
Post by ElMastro »
All right, I can confirm that gmsh works like a charm, mesh is loaded within FreeCAD without problem, but as I try to set the material or set the condition of the Analysis it gives the problem.
I remember having problems in the update of the python dependencies of Freecad some time ago (a few weeks I believe). This to me sounds as bug, and probably the best think could be to inform the developers.
Post by bernd »
it seams all python FEM task panels do not work for you ...
They might be missing. Does it even not work if you start FreeCAD from Build directory?
Would you run this code:
FreeCAD.getHomePath() + "Mod/Fem/Resources/ui/MeshGmsh.ui"
For me it gives ...
'C:/0_BHA_privat/progr/FreeCAD_0.19.xxxxx_Py3Qt5/Mod/Fem/Resources/ui/MeshGmsh.ui'
Than in the directory printed ... there are the ui files ... screen attached ...
Post by wmayer »
According to the error message the .ui file can be loaded and a form created. But for some reason the mechanism to access a sub-control by its name doesn't work.
Here some test code you can try:
form = FreeCADGui.PySideUic.loadUi(FreeCAD.getHomePath() + "Mod/Fem/Resources/ui/MeshGmsh.ui")
form
form.if_max # this doesn't seem to work for you
from PySide2 import QtWidgets
f=form.findChildren(QtWidgets.QLineEdit)
f[0].metaObject().className()
f[0].objectName()
form.show()
ElMastro
Post by ElMastro »
running
it says
'/usr/lib/freecad/Mod/Fem/Resources/ui/MeshGmsh.ui'
and the folders contains all the files
ls /usr/lib/freecad/Mod/Fem/Resources/ui/
ElectrostaticPotential.ui  FlowVelocity.ui         MeshGroup.ui
ElementFluid1D.ui          InitialFlowVelocity.ui  MeshGroupXDMFExport.ui
ElementGeometry1D.ui       Material.ui             MeshRegion.ui
ElementGeometry2D.ui       MeshBoundaryLayer.ui    ResultShow.ui
ElementRotation1D.ui       MeshGmsh.ui             SolverCalculix.ui
That there are on your version
When I ran the code
form
f[0].objectName()
form.show()
This appear
https://ibb.co/fDng019
Which I remember to be the form I used when I used the fem.
Post by wmayer »
But what's the output for each line of code?
