conda-packages for osx
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
ballan
Re: conda-packages for osx
Postby ballan » Sun May 05, 2019 7:01 am
Hi, I've been trying to build FreeCAD locally on Mac OS Mojave using conda, but I keep running into errors related to the SDK version.
I started by cloning the freecad-feedstock repo, and tried to build the recipe inside it:
conda build recipe -m .ci_support/osx_python3.7.yaml
I've already downloaded the older SDKs and put them under /opt, and added this path to my conda_build_config.yaml file:
$ cat ~/.conda/conda_build_config.yaml
CONDA_BUILD_SYSROOT:
  - /opt/MacOSX10.9.sdk
$ ls /opt
MacOSX10.10.sdk  MacOSX10.11.sdk  MacOSX10.12.sdk  MacOSX10.13.sdk  MacOSX10.9.sdk  X11  apps
When running conda build, it seems to pick up my conda_build_config:
Adding in variants from internal_defaults
Adding in variants from /Users/ben/.conda/conda_build_config.yaml
Adding in variants from .ci_support/osx_python3.7.yaml
Here's the error I get, I presume because the wrong version of the SDK is being referenced somewhere.
ninja: error: '/Applications/Xcode-9.0.1.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/System/Library/Frameworks/AppKit.framework', needed by 'Mod/Import/Import.so', missing and no known rule to make it
I'm not really sure why CONDA_BUILD_SYSROOT isn't being respected. Can anyone advise me on what I'm doing wrong? I wasn't sure if you'd prefer this post to go here or in a new thread, apologies if it's the wrong place.
vectronic
Postby vectronic » Thu May 09, 2019 11:09 pm
I've managed to do a repeatable build on macOS using the steps I've posted on my blog:
https://vectronic.io/posts/building-fre ... ing-conda/
Posting here in case it helps someone out at some point.
ballan
Postby ballan » Sat May 11, 2019 12:07 am
Thanks a lot for posting those instructions vectronic! I’m away from my mac so won’t be able to try it for a while, but the step I was missing was creating the symlinks to the SDK in a place where the ci scripts could find them.
Brutha
Postby Brutha » Sun May 12, 2019 11:52 am
Perfect, thank you very much for that, have been looking for this for some time! I will link to this post in my older message about the space navigator.
Couple of quick questions in case you or someone else has some ideas:
1) Do you know if we could take the latest dev version of Freecad instead of 18? This gives me a version info below.
2) Do you know if we can package this as an app, rather than running from Terminal?
Cheers,
Brutha
OS: macOS 10.14
Version: 0.18.16110 (Git)
Branch: (HEAD detached at 0.18.1)
Python version: 3.7.3
Qt version: 5.6.2
vectronic
Postby vectronic » Sun May 26, 2019 3:10 pm
NOTE: To modify the version of FreeCAD which is build, edit recipe/meta.yaml and change the version variable e.g.:
    {% set version = "master" %}
I have been unable to build a MacOS app. I have had an attempt with the following but have given up...
1. Editing recipe/build.sh and adding:
      -D FREECAD_CREATE_MAC_APP=ON \
2. Modifying the checked out source in the folder such as:
/Users/vectronic/miniconda3/envs/freecad_master/conda-bld/freecad_1558826326190/work/src/MacAppBundle/CMakeLists.txt
so that:
install(PROGRAMS "${Qt5Core_DIR}/../../../libexec/Assistant.app/Contents/MacOS/Assistant" DESTINATION ${CMAKE_INSTALL_PREFIX}/MacOS)
reads:
install(PROGRAMS "${Qt5Core_DIR}/../../../bin/Assistant.app/Contents/MacOS/Assistant" DESTINATION ${CMAKE_INSTALL_PREFIX}/MacOS)
With these changes, I was able to get a FreeCAD.app to be built in the conda package. However, the conda test phase fails and MacOS tells me the FreeCAD.app is corrupt...
looo
Postby looo » Sun May 26, 2019 3:17 pm
I guess the tests doesn't make much sense if the package is modified this way.
looo
Postby looo » Thu May 30, 2019 1:02 pm
Finally a conda-package for freecad (qt5.9) was uploaded to freecad/label/testing.
Would be nice if a mac user can try this. I have currently no access to my mac:
as usual install miniconda and then create environment with:
conda create -n freecad_qt59 freecad -c freecad/label/testing -c conda-forge
chrisb wrote: ping ping ping
Postby chrisb » Thu May 30, 2019 1:18 pm
I will look at this later. I don't have a development environment, so I will wait until it occurs at the official download page at https://github.com/FreeCAD/FreeCAD/releases/
looo
Postby looo » Fri May 31, 2019 8:17 am
I updated osx 0.19 bundle to use qt5.9 The generated bundle should include FreeCAD 0.19.16881.
Please report back. Maybe you can also try to close the WebGui widget. This results in a crash on linux.
vectronic
Postby vectronic » Fri May 31, 2019 9:24 am
No dice...
/Applications/FreeCAD.app/Contents/MacOS/FreeCAD
FreeCAD 0.19, Libs: 0.19R16881 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
/Applications/FreeCAD.app/Contents/MacOS/FreeCAD: line 10: 14378 Abort trap: 6           "$PREFIX/bin/FreeCAD" $@
Let me know if there is something I should run to get more useful output...
Also, did you build this using conda and then package as a macOS app? If so do you have any instructions to take the binary produced from the conda build and produce the app/dmg?
