Function when a workbench opens a new file.
keithsloan52
Postby keithsloan52 » Thu May 30, 2019 3:55 am
I wish to create some FreeCAD objects when a new file is created. I only want to do this when a particular workbench is active.
Where in the implementation of a particular workbench could I add code to perform something when a new file is opened.
Re: Function when a workbench opens a new file.
Postby wmayer » Thu May 30, 2019 7:39 am
Use the C++ class DocumentObserver and override its slotCreatedDocument. But note that the Document is passed as a const reference. So you can try to use const_cast to directly add a new object there which should be safe to do. The only thing you have to take care of is that the Label of the document is not yet defined at that time.
Here is a minimum example in Python only for demonstrating purposes:
class DocObserver(object):
    def slotCreatedDocument(self, doc):
        doc.addObject("Part::Feature", "Shape")
doc=DocObserver()
App.addDocumentObserver(doc)
Postby wmayer » Thu May 30, 2019 7:43 am
About the current workbench you can use the class WorkbenchManager which has the method active() that returns a pointer of a Workbench.
In Python you can do:
wb=Gui.activeWorkbench()
wb.GetClassName()
keithsloan52
Postby keithsloan52 » Thu May 30, 2019 12:28 pm
doc=DocObserver()
So I do that in the workbenches InitGui.py ?
Postby wmayer » Thu May 30, 2019 1:03 pm
For example.
keithsloan52
Postby keithsloan52 » Thu May 30, 2019 3:30 pm
For example.
Well I would like a workbench lets just call it bench. When it is active and somebody opens a new file I would like to initiate the new file with a couple of new objects for now lets just say a single Sphere.
Postby wmayer » Thu May 30, 2019 3:52 pm
With the two Python snippets above you should be able to do it. I guess the active workbench you are talking about is the one of your InitGui.py file. So, the easiest would be to add the observer in the workbench's Activated method and remove it in its Deactivated method.
keithsloan52
Postby keithsloan52 » Fri May 31, 2019 6:01 am
Thanks Werner
What is the function to remove the Observer? App.removeDocumentObserver(doc) ?
I tried search for doc on App.addDocumentObserver() hoping to find how to remove but not much luck with my searches.
Thanks Keith
Postby wmayer » Fri May 31, 2019 8:13 am
Yes, App.removeDocumentObserver() is your friend. Actually you should be able to see this method when using FreeCAD's Python console as it automatically lists all methods of an object when pressing "."
keithsloan52
Postby keithsloan52 » Fri May 31, 2019 9:47 am
Okay I am missing something as I get the follow error message
name 'DocObserver' is not defined
  File "<string>", line 65, in Activated
My code in InitGUI.py looks like
import FreeCAD
        mySphere = doc.addObject("Part::Sphere", "Globe")
        mySphere.Radius = 100
class Astro_Workbench ( Workbench ):
    "Astro workbench object"
    def __init__(self):
        self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/Astro/Resources/icons/AstroWorkbench.svg"
        self.__class__.MenuText = "Astro"
        self.__class__.ToolTip = "Astro workbench"
    def Initialize(self):
        def QT_TRANSLATE_NOOP(scope, text):
            return text
        import AstroCommands
        commands=['AddRegionCommand' ]
        toolbarcommands=['AddRegionCommand']
        self.appendToolbar(QT_TRANSLATE_NOOP('Workbench','AstroTools'),toolbarcommands)
        self.appendMenu('Astro',commands)
        #FreeCADGui.addIconPath(":/icons")
        FreeCADGui.addIconPath(FreeCAD.getResourceDir() + \
                              "Mod/Astro/Resources/icons")
        FreeCADGui.addLanguagePath(":/translations")
        #FreeCADGui.addPreferencePage(":/ui/openscadprefs-base.ui","OpenSCAD")
    def Activated(self):
        "This function is executed when the workbench is activated"
        doc=DocObserver()
        return
    def Deactivated(self):
        "This function is executed when the workbench is deactivated"
        return
           def GetClassName(self):
        "This is executed whenever the user right-clicks on screen"
        return "Gui::PythonWorkbench"
        return
    def ContextMenu(self, recipient):
        # "recipient" will be either "view" or "tree"
        #self.appendContextMenu("My commands",self.list) # add commands to the context menu
Gui.addWorkbench(Astro_Workbench())
Will have to give the FreeCAD python console a try I am still on the old fashioned way of doing things
