Draft Scale doesn't Work in FC0.19.16883
Just that. Draft Scale doesn't perform any action after the Ok in the scale task panel. No error message either.
OS: Windows 10 (10.0)
Version: 0.19.16883 (Git)
Hash: aedb888ae3bb001175fe86211b6cfb826e31a918
Python version: 3.6.8
Qt version: 5.12.1
Qt version: 5.12.1
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: Draft Scale doesn't Work in FC0.19.16883
Confirmed. Preview behavior is even different depending whether the reference point is entered with coordinates or mouse.
I think it can be a glitch in the dev that pushes a somewhat lamous code in the daily build.
I found this issue while trying to replicate issue #3980, thus I'll check again in a few days and will open a new ticket if needed.
It seems to work OK for me... Care to indicate a precise step-by-step procedure to reproduce the issue?
(moved to help forum as it's not specifically a development issue)
2 different cases.
Case 1 : reference point with mouse
- Create a new blank document
- Add a cube with Part WB -> Create a Cube
- Select the cube and choose Draft WB -> Scale
- Click the reference point in the 3D view (eg. at the left of the cube), then in the next Task screen change the X/Y/Z factors (eg. to '2') => The scaled cube is correctly previewed in light red color
- Eventually check "Copy" option in the Task panel (will better demonstrate the failure) then validate Task with "Ok" => The (eventually copied) cube is similar (not scaled) to the original one. Moreover, it doesn't expose any scale property in the Data tab of Combo view.
- Same as previous
- Same as previous
- Same as previous
- Enter reference point coordinate by entering 3x '0' + 'Enter', then in the next Task screen change the X/Y/Z factors (eg. to '2') => No preview is displayed
- Same as previous, same failure
Now I'm gonna upgrade to daily build of today and see if it's still the same.
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19. (2019/06/01)
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/France (fr_FR)
Just creating a Rectangle in Draft Wb and then Draft Scale'ing it by 2 in X and Y produces this output in Report View if it assists:
Using:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.16878 (Git)
Hash: 50f91840d677ba77d3a938d9ac0aa73f6a9f12d4
Qt version: 5.12.1
While repeating the exercise using the below older build works as expected:
OS: Windows 7
Version: 0.19.16653 (Git)
Hash: aaae82970461c10b76281f4e4454ab086b5f7f21
Python version: 3.6.6
Qt version: 5.6.2
Loading Draft module...done
Draft workbench activated
Pick first point
Pick opposite point
Pick base point
('[Draft.todo.commit] Unexpected error:', <class 'AttributeError'>, 'in ', ['Draft.scaleVertex(FreeCAD.ActiveDocument.Rectangle, 1, FreeCAD.Vector(2.0,2.0,1.0), FreeCAD.Vector(-20.002185821533203,-26.939483642578125,0.0))', 'FreeCAD.ActiveDocument.recompute()'])
Qt version: 5.12.1
OS: Windows 7
Qt version: 5.6.2
I like gif evidence
Qt version: 5.12.1
OS: Windows 10 (10.0)Word size of OS: 64-bit
Qt version: 5.12.1
::bitacovir::
Exact same faulty behavior with daily build of today :
Version: 0.19. (2019/06/02)
Qt version: 5.9.5
Qt version: 5.9.5
Hmm many regressions because of last changes to allow working on subelements... I hadn't noticed the clone option had been removed too... Should have watched this closer... *EDIT* Fixed in git commit e2f65ef01
moving this back to Draft since it's after all tied with recent developments
