I think I'm seeing some geometry "improvisation' by the PartDesign fillet tool. I was able to replicate it in a simple model. (Attached.)
Has anyone else noticed this? Is this a bug to report or is there another explanation?
(All pictures are orthographic).
Overview:
Right View Before Fillet:
Right View After Fillet:
OS: macOS 10.14
Version: 0.18.16117 (Git)
Branch: (HEAD detached at 0.18.2)
Python version: 3.6.7
Qt version: 5.6.2
[Solved] Fillet geometry error
- After Fillet Top.png (33.33 KiB) Viewed 559 times
- filletbug.FCStd
- Model replicating issue.
- (76.88 KiB) Downloaded 17 times
Re: Fillet geometry error
This is a display artefact, mainly due to deflection setting.
You can change it at body level (view tab of the property editor) - set it to eg. 1° - then force the whole document to recompute by right-clicking on "filletbug" -> "Mark to recompute" -> F5 key.
Thank you for that explanation. I suspected display-only artifact, but I was thrown off that it looked the same every way I looked.
In your file datumplane is not attached, it's not tangent. That gives an error.
- aa.FCStd
- (68.78 KiB) Downloaded 14 times
Thanks for taking a look. I intentionally put the datum plane to be slightly below the top of the object. (Z=14.9mm; object has 15mm radius.) That allowed me to show the portion sticking above the plane easily in pictures.
Tried this morning. This is definitely it. Both Angular deflection and deflection improve the view. More importantly, knowing it's a view artifactly only, and knowing how to affect it are key. It allows me to ignore it or temporarily change it to keep computation faster.
Re: [Solved] Fillet geometry error
This artifact is highly seeable here also because your model is at a very small size.
Also be aware that this parameters will have direct effect on the result if you export as mesh (typically STL).
