QtXmlPatterns Available in Travis Win Build?
wandererfan
Postby wandererfan » Sat Jun 08, 2019 10:18 pm
We're having some trouble debugging PR 2238. Builds & tests fine in Linux, but we get a failure for Win:
c:\users\travis\build\freecad\freecad\src\mod\techdraw\app\qdomnodemodel.h(4): fatal error C1083: Cannot open include file: 'QAbstractXmlNodeModel': No such file or directory [C:\Users\travis\build\FreeCAD\FreeCAD\build\src\Mod\TechDraw\App\TechDraw.vcxproj]
Does anybody know how to tell if Qt XML Patterns is available in Travis Win builds?
Thanks,
wf
sgrogan
Re: QtXmlPatterns Available in Travis Win Build?
Postby sgrogan » Sun Jun 09, 2019 4:37 pm
Yes, it's in the Libpack used.
abdullah
Postby abdullah » Sun Jun 09, 2019 5:15 pm
Thanks,
wf
This is the content of the freecadlibs library:
FreeCADLibs/include/QtXmlPatterns$ ls
5.12.1                     qabstractxmlnodemodel.h  qsourcelocation.h       qtxmlpatternsversion.h  QXmlNamePool        qxmlresultitems.h      qxmlserializer.h
QAbstractMessageHandler    QAbstractXmlReceiver     QtXmlPatterns           QXmlFormatter           qxmlnamepool.h      QXmlSchema
qabstractmessagehandler.h  qabstractxmlreceiver.h   qtxmlpatterns-config.h  qxmlformatter.h         QXmlNodeModelIndex  qxmlschema.h
QAbstractUriResolver       QSimpleXmlNodeModel      QtXmlPatternsDepends    QXmlItem                QXmlQuery           QXmlSchemaValidator
qabstracturiresolver.h     qsimplexmlnodemodel.h    qtxmlpatternsglobal.h   QXmlName                qxmlquery.h         qxmlschemavalidator.h
QAbstractXmlNodeModel      QSourceLocation          QtXmlPatternsVersion    qxmlname.h              QXmlResultItems     QXmlSerializer
May this be related to caps?
I see the build error in Travis:
CMake does not need to re-run because C:/Users/travis/build/FreeCAD/FreeCAD/build/src/Mod/TechDraw/App/CMakeFiles/generate.stamp is up-to-date.
  QDomNodeModel.cpp
May this be cmake related?
tpavlicek
Postby tpavlicek » Sun Jun 09, 2019 6:35 pm
Hi to all,
sorry, I was without access to my computer during the weekend. @Abdullah Yes, I am quite sure the missing QAbstractXmlNodeModel header is the problem and as was pointed out, the QXmlPatterns library + all headers needed is present in the libpack. Maybe tomorrow I will be able to get my hands on a Windows machine with VS 2015 installed, so I will try the Windows build and hopefully find out what's going on.
Thanks to all of you for help and support, I am sorry for the inconvenience,
Tomas
Postby wmayer » Sun Jun 09, 2019 10:38 pm
As it OK to merge the PR as soon as the Win issues are fixed?
wandererfan
Postby wandererfan » Mon Jun 10, 2019 12:32 am
Better to wait. Still some minor issues - https://forum.freecadweb.org/viewtopic. ... 43#p313088
apeltauer
Postby apeltauer » Mon Jun 10, 2019 3:47 am
Just a hint from my side.
Do we need to add the xml stuff by the cmake config??
Ps: right know I have no access to my machine, just cell phone, otherwise I just looked by myself...
tpavlicek
Postby tpavlicek » Mon Jun 10, 2019 11:38 am
Hello,
finally, the Windows build is successful :-) Thanks all of you for helping hands!
There were several problems, but the important ones were:
  • There is a difference in CMake treatment between Qt4 and Qt5. Qt4 uses QT_QTXMLPATTERNS_INCLUDE_DIR + QT_QTXMLPATTERNS_LIBRARY, while Qt5 sets Qt5XmlPatterns_INCLUDE_DIRS and Qt5XmlPatterns_LIBRARIES.
  • Windows DLLs require __declspec(dllexport) / __declspec(dllimport) depending on whether the DLL functions are exported resp. imported.This needs to be declared directly in the class definition.
Once again thanks and sorry for inconvenience,
Tomas
wandererfan
Postby wandererfan » Mon Jun 10, 2019 11:59 am
Terrific!
I've pushed a fix for Annotations to your branch and Travis is running now. Maybe we want to squash some commits to make the history cleaner?
I don't have a solution for existing custom Templates. They need to have their font sizes adjusted, yes? Can we write a little script to do this?
tpavlicek
Postby tpavlicek » Mon Jun 10, 2019 12:06 pm
Hi WandererFan,
sure no problem with squashing the commits - at least for these with CMake changes this is more than desirable. As for the custom templates, let me take a look on them, definitely the new Russian templates must be updated as well and have the xml:space="preserve" attribute removed from the <text> elements.
Kind regards,
Tomas
PS: Thanks for Your additional fixes!
