Issue with SVG export
Shack
Re: Issue with SVG export
Post by Shack »
Alright, after some digging I have now found something which appears to be a fix.
https://github.com/FreeCAD/FreeCAD/blob ... /getSVG.py
Line 274:
if round(edge.Curve.Axis.getAngle(drawing_plane_normal),2) == 0:
If I change this as so:
if round(edge.Curve.Axis.getAngle(drawing_plane_normal),2) in [0, 3.14]:
now all my SVG exports are working perfectly.
I tried some of my complex stepfiles which has failed before and did -> 2D projection -> export SVG, and everything seems perfect!
only thing im wondering, is this the actual bug, or shouldn't the 2D projection make the angles in the first place?
I will make a PR tomorrow when I have some more time.
openBrain
Post by openBrain »
Shack wrote: Tue Jun 11, 2019 11:46 pm Alright, after some digging I have now found something which appears to be a fix.
Woh ! Congrats for your tenacity on this. ;)
However I think your patch isn't totally correct.
Functionally, the goal of line 274 is to determine if the circle is parallel to flattening plane, in order to know if it shall be exported as a circle or an ellipse.
From my short first review, it looks like one property doesn't return the expected value. IMO
  • Either "Axis" returns the direction of AngleXU instead of perpendicular vector
  • Or "getAngle" returns the AngleXU itself instead of a calculated angle between circle normal & projection plane normal
This would need some extra investigations to propose a correct PR. ;)
I can do that later on the day. Or feel free to do it yourself if you have some spare time. :)
Shack
Post by Shack »
Thanks! :P this has been bugging me for years.
I figured this probably wasn't the correct way to fix it :)
If you have time to help investigate that would be great!
I'm just interested in getting it fixed properly :)
Thanks for your help
openBrain
Post by openBrain »
OK, some steps forward. :)
Here what I get when using your example file and selecting the circle then running :
>>> Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Axis.getAngle(App.Vector(0,0,1))
3.141592653589793
Float number computation at work I guess. :lol:
So I think the line #274 could be easily patched like this :
if round(edge.Curve.Axis.getAngle(drawing_plane_normal) % math.pi, 2) == 0:
No time ATM to test, but I'll do when possible. Good thing if you can test this patch on your side too. ;)
Shack
Post by Shack »
thanks! Ill have a look at it later :)
meanwhile have a look at line 158 in getSVG.py
if round(c.Axis.getAngle(drawing_plane_normal),2) in [0, 3.14]:
openBrain
Post by openBrain »
Indeed it actually works. This is same behavior, but looks less readable to me. While probably being more efficient at CPU usage.
Both works I guess. Let you choose which one you want to include in the PR. ;)
openBrain
Post by openBrain »
Shack wrote: Wed Jun 12, 2019 2:41 pm thanks! Ill have a look at it later :)
I tested and both works fine. Probably for consistency, it's better to keep the same (i.e. your first patch proposal).
Would you make the ticket & PR, or should I do it ?
Shack
Post by Shack »
I made a PR now
https://github.com/FreeCAD/FreeCAD/pull/2258
should a ticket also be made on the bug tracker?
openBrain
Post by openBrain »
I don't know. Let's ask someone that probably knows. ;)
Kunda1 wrote: Fri Oct 12, 2018 12:36 pm Ping
@Kunda1, should a bug ticket also be filled in the case of a PR ?
Post by Kunda1 »
openBrain wrote: Wed Jun 12, 2019 7:45 pm should a bug ticket also be filled in the case of a PR ?
Nope, not necessary. In fact it's not encouraged anymore. Thanks for asking :D
Though it is important to notify the folks maintaining the 0.19 changelog in https://forum.freecadweb.org/viewtopic.php?f=10&t=34586
