Property angle of axes doesn't work
Hello,
when I create an axes and try to set the angle to 90° the axes is displayed with an undefined length.
See attached picture....To rotate the axis I have to set the placements properties.
Somebody find out the same problem?
The problem is in FC18 and in FC19.
Thanks,
Marco
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
OS: Windows 10 (10.0)
Version: 0.19.16824 (Git)
Hash: 81ae5688d48fe9037f431b5cb8e1c9cee07f22b9
Python version: 3.6.8
Qt version: 5.12.1
Thanks,
Marco
Qt version: 5.6.2
Qt version: 5.12.1
- Angle_Axes.png (99.86 KiB) Viewed 1948 times
Re: Property angle of axes doesn't work
Please try the following steps:
1) Create an axes
2) Set the length to 3000mm
3) Set the angle to 45 degrees
4) Draw the dimension of the axis and you see 4242.64mm
The angle changes the length of the axes. With an angle of 90° the length became endless.
I found out another problem. If the angle is 90 or 270 degrees and you change the Bubble Size and the Font Size they aren't updated/displayed correctly in the model....Or maybe the length of the axes is endless and the bubble isn't visible on the screen...
Can you confirm this?
Thanks, Marco
Qt version: 5.6.2
1) Create an axes
Thanks, Marco
Qt version: 5.6.2
hi
comportment normal ; base height 3m
if the angle change the end line go up to height 3m and may seem infinite if the angle is small
mario
mario
Hi @mario52,
Thanks for your test,
which version of FreeCAD are you using?
Marco
Marco
hello
i faced this problem too ,the problem is the equation that used to draw the axis and i fixed it for my self ,here is the correct equation
p2 = Vector(dist+l*math.sin(ang),l*math.cos(ang),0)
so now how can you fix it your self:
go to the FreeCAD file /Mod/Arch and open the ArchAxis.py (python file)and look for Class _Axis/def excute() and compare your equation with this one ,and now it's your's ,correct it if want ,leave it if you don't
thank you
thank you
You may fix it on Github and make a pull request!
The community would be happy to help you learn how to use Github. It is worth it and facilitates faster reviewing/testing. There is a a page on the wiki dedicated to this: Github. There is also a thread dedicated to this, I can't seem to recall where... but open a new thread and ask for assistance.FATHI RAMMAH wrote: ↑Thu Jun 13, 2019 12:23 pmi really like to do that but i'm not familiar with gethub yet ,so if you can fix it on gethub so that would be great .
You can also "propose file change" online by clicking on the pencil on the upper right part of github file viewer on the webpage. That's really simple and you don't have to fork or clone the project on your machine. Be careful, it's easy to get addicted!
One point to make here, is always create a new branch, and not save to exisiting master branch. This is typical newbie mistake.
