Better than mine right side arc and spirals look good
Civil engineering feature implementation (Transportation Engineering)
- HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
I think I was overtired or something when I pushed the code last week - I forgot some really critical code (like the code that tells it to draw the spiral!) so it's been substituting straight lines in for the spirals. I'm getting it figured out now, though. Hopefully will have something in the next day or so.
- HakanSeven12
In your screenshot, some alignments first line is missing. For example Yanyol 202.
- Joel_graff
I'll take a closer look at that...HakanSeven12 wrote: ↑Wed Jun 12, 2019 6:27 pm In your screenshot, some alignments first line is missing. For example Yanyol 202.
I'm currently trying to sort out an issue with "K2 E Kolu".
Specifically, the geometry starting at line 974:
<Curve rot="cw" chord="1.490629760303" crvType="arc" delta="0.840768439589" dirEnd="199.748605272655" dirStart="200.589373712244" external="0.002734306578" length="1.490643134534" midOrd="0.00273423298" radius="101.582738299146" tangent="0.745334941822">
<Start>4275265.150289229117 508814.41553000838</Start>
<Center>4275360.244407110848 508778.692127809045</Center>
<End>4275264.636334692128 508813.016306003497</End>
<PI>4275264.888178758323 508813.717803520034</PI>
</Curve>
<Line dir="199.748605286717" length="1.8633819771">
<Start>4275264.636334692128 508813.016306003497</Start>
<End>4275264.0067094611 508811.26252025232</End>
</Line>
<Curve rot="cw" chord="289.328978525251" crvType="arc" delta="116.634131201892" dirEnd="82.681228175862" dirStart="199.315359377754" external="153.674990370323" length="346.060433644311" midOrd="80.712903808363" radius="169.999999999696" tangent="275.436924523811">
<Start>4275264.006709448062 508811.262520213262</Start>
<Center>4275424.437803187408 508755.032064394094</Center>
<End>4275446.094031156041 508586.417095337238</End>
<PI>4275172.901157593355 508551.329302228231</PI>
</Curve>
- Joel_graff
Fixed.HakanSeven12 wrote: ↑Wed Jun 12, 2019 6:27 pm In your screenshot, some alignments first line is missing. For example Yanyol 202.
Three issues remain:
1. The alignment "K2 E Kolu" does not render because of the aforementioned curve bearing issues. Not sure how to process what looks like incorrect data.
2. There's a curve rendered far above the alignment. I think this is an artifact resulting from issue #1.
3. "K2 C Kolu" renders incorrectly because it has an arc-spiral-arc segment. I have yet to implement support for this case.
- HakanSeven12
I created it from polyline. Maybe this couse the problem. Its can't fit perfectly.Joel_graff wrote: ↑Wed Jun 12, 2019 8:04 pm The issue is the bearings are discontinuous. That is the 'dirEnd' attribute of the first curve matches the 'dir' attribute of the Line, but the 'dirStart' attribute is off by about 0.434 degrees. That causes it to crash on this alignment. I could force it to render it anyway, I suppose... But you may want to look at that.
- HakanSeven12
You almost finished spiral implementationJoel_graff wrote: ↑Wed Jun 12, 2019 8:14 pm Fixed.
- Joel_graff
In a case where there's a significant error in the data, the only thing I can propose is to simply replace the curve with a tangent connecting the starting and end points. That would allow the alignment to be imported, and the user could go back and fix the alignment in FreeCAD after the fact.HakanSeven12 wrote: ↑Wed Jun 12, 2019 8:15 pm I created it from plyline. Maybe this couse the problem. Its can't fit perfectly.
- HakanSeven12
I will take a look tomorrow.
- HakanSeven12
What do you mean by that?Joel_graff wrote: ↑Wed Jun 12, 2019 8:14 pm 2. There's a curve rendered far above the alignment. I think this is an artifact resulting from issue #1.
