How to activate openCamLib after compiling it
Erich Schulz
Re: How to activate openCamLib after compiling it
Post by Erich Schulz »
done
Thanks!
sgrogan
Post by sgrogan »
I made a small update.
"fight the good fight"
Erich Schulz
so...
I have successfully compiled OCL... (using the readme https://github.com/aewallin/opencamlib per https://www.freecadweb.org/wiki/OpenCamLib)
and have a functioning version of freecad daily...
but I am getting `OpenCamLib is not working!` (twice AND in red!!!) when I open the path workbench.
any clues??? :?
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
sgrogan
Post by sgrogan »
Erich Schulz wrote: Wed Jun 26, 2019 12:13 am any clues??? :?
I think you need to set this in CMake
cmake -DBUILD_PY_LIB=ON -DUSE_PY_3=OFF ../src
See also here: https://forum.freecadweb.org/viewtopic. ... 20#p311763
This is part of zach's GSoC so I think it's OK to ping him in that topic. He had an upstream ocl pull request merged that helps this.
You can turn off or leave on the cxx libs and doc's (FreeCAD doesn't need them).
Erich Schulz
ok... i've been banging at the keyboard randomly....
I've added the following to my bash history :-)
sudo make install
cmake -DBUILD_PY_LIB=ON ../src
sudo make install
history | tail
at this point I seem to have several likely looking files based on the end of the last install:
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /usr/local/lib/python2.7/dist-packages/ocl.so
-- Up-to-date: /usr/local/lib/python2.7/dist-packages
-- Up-to-date: /usr/local/lib/python2.7/dist-packages/camvtk.py
-- Up-to-date: /usr/local/lib/python2.7/dist-packages/pyocl.py
-- Up-to-date: /usr/local/lib/python2.7/dist-packages/procmemory.py
-- Up-to-date: /usr/local/lib/python2.7/dist-packages/STLTools.py
-- Up-to-date: /usr/local/lib/opencamlib/libocl.so.2018.08.122
-- Up-to-date: /usr/local/include/opencamlib/arc.hpp
-- Up-to-date: /usr/local/include/opencamlib/bbox.hpp
-- Up-to-date: /usr/local/include/opencamlib/ccpoint.hpp
-- Up-to-date: /usr/local/include/opencamlib/clpoint.hpp
-- Up-to-date: /usr/local/include/opencamlib/line.hpp
-- Up-to-date: /usr/local/include/opencamlib/path.hpp
-- Up-to-date: /usr/local/include/opencamlib/stlreader.hpp
-- Up-to-date: /usr/local/include/opencamlib/stlsurf.hpp
-- Up-to-date: /usr/local/include/opencamlib/triangle.hpp
-- Up-to-date: /usr/local/include/opencamlib/point.hpp
-- Up-to-date: /usr/local/include/opencamlib/ballcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/bullcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/compositecutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/conecutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/cylcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/ellipseposition.hpp
-- Up-to-date: /usr/local/include/opencamlib/millingcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/ellipse.hpp
-- Up-to-date: /usr/local/include/opencamlib/adaptivepathdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/pathdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/batchdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/pointdropcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/brent_zero.hpp
-- Up-to-date: /usr/local/include/opencamlib/kdnode.hpp
-- Up-to-date: /usr/local/include/opencamlib/kdtree.hpp
-- Up-to-date: /usr/local/include/opencamlib/numeric.hpp
-- Up-to-date: /usr/local/include/opencamlib/lineclfilter.hpp
-- Up-to-date: /usr/local/include/opencamlib/clfilter.hpp
-- Up-to-date: /usr/local/include/opencamlib/halfedgediagram.hpp
-- Up-to-date: /usr/local/include/opencamlib/operation.hpp
-- Up-to-date: /usr/local/include/opencamlib/batchpushcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/fiberpushcutter.hpp
-- Up-to-date: /usr/local/include/opencamlib/fiber.hpp
-- Up-to-date: /usr/local/include/opencamlib/interval.hpp
-- Up-to-date: /usr/local/include/opencamlib/waterline.hpp
-- Up-to-date: /usr/local/include/opencamlib/adaptivewaterline.hpp
-- Up-to-date: /usr/local/include/opencamlib/weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/simple_weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/smart_weave.hpp
-- Up-to-date: /usr/local/include/opencamlib/weave_typedef.hpp
-- Up-to-date: /usr/local/include/opencamlib/tsp.hpp
but still I get "OpenCamLib is not working!"
Erich Schulz
I am getting some warnings during the build about boost - but the process seems to roll on - is that the problem or is this a path issue??
Russ4262
Post by Russ4262 »
Evening, Sir.
Was just looking through your posts here.
Erich Schulz wrote: Wed Jun 26, 2019 12:13 am so...
any clues??? :?
Version: 0.19.
Qt version: 5.9.5
and this one...
Erich Schulz wrote: Wed Jun 26, 2019 3:34 am ok... i've been banging at the keyboard randomly....
My observation is that your nightly build is for Python 3.6 and your recent successful build of OCL is for Python 2.7 based upon quoted code snippet above.
You will need to attempt an OCL build with Python 3.6 - probably a CMake flag or similar in the source/build files.
OR
You will need to install a nightly build based on Python 2.7 that should be compatible with your successful OCL build for Python 2.7.
Disclaimer: I don't have a Linux machine, so perhaps I don't have the whole picture.
Best wishes,
Russ
quick61
Post by quick61 »
Your FreeCAD Python version is 3.6.8 and your building OCL for 2.7. Not going to work. Please let me know if you get OCL to build with Python 3.6.8. on 18.04.2, and how you did it. Haven't figured that one out yet....
Mark
Erich Schulz
thanks Russ - I thought I had both a 3.x and 2 version - but like you I'm a bit out of my depth :-/
