boxcreator on Freecad 0.18
harlekin
Post by harlekin »
I apologize for having made a mistake in writing the previus post.
I Use Freecad0.18 ver. 16117. I downloaded from Gitub the very interesting macro BOXCREATOR. But it does not function.
Though I searched the forum i did not find a solution.
I unfolded the .zip file and copied the _init_.py and boxcreator.py to the directory users\username\appData\roaming\freecad\macro (here are located other functioning macros).
If i run rhe _init_.py have an error message telling me "cannot import name 'boxcreator'
If i run the boxcreator.py nothing happens.
Some years ago i used successfully the macro with earlier version of freecad.
Thanks in advance for help.
Re: boxcreator on Freecad 0.18
You can install it with the AddonManager, available from the Tools menu.
harlekin
Post by harlekin »
Thanks for the answer but if i run the AddonManager i do not fint the boxcreator into the list of macros.
kisolre
Post by kisolre »
OS: Windows 8.1
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Bulgarian/Bulgaria (bg_BG)
harlekin
Post by harlekin »
In the marco window i have the macro installed
but in the addonmanager i don't see the boxcreator macro to update
thanks a lot for the vasted time
kisolre
Post by kisolre »
Not sure but it might be that Addon manager sees something with the same name that is already there but not quite right and tries not to brake it. So it does not suggest things that install over it.
Here is what I have in my Macro folder:
BoxCreator_macro folder.JPG (83.53 KiB) Viewed 2222 times
BoxCreator_macro folder_2.JPG (29.14 KiB) Viewed 2222 times
and what I see as macros:
Delete those files, restart FreeCAD, check addon manager again.
harlekin
Post by harlekin »
Although your answers nothing new.
Perhaps its better i postpone the problem. An idea could come later.
Thanks a lot.
Syres
Post by Syres »
harlekin wrote: Sat Jun 29, 2019 6:51 pm but in the addonmanager i don't see the boxcreator macro to update
I can confirm that the Boxcreator macro does not appear in my AddonManager list and I've never had it installed previously. I believe the reason for new users (or those of us who never had the macro) not seeing macros such as this one is that they must have an entry in the Wiki e.g. https://www.freecadweb.org/wiki/Macro_A ... _%26_Scale
I've searched for Boxcreator and can find no entry.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17171 (Git)
Hash: d19470a9711ea604f3ca6c93e46afadf64d5bb87
Python version: 3.6.8
Qt version: 5.12.1
Syres
Post by Syres »
harlekin wrote: Sun Jun 30, 2019 7:04 am Perhaps its better i postpone the problem.
I've just carried out the manual installation and although @kisolre has shown the correct info maybe a step-by-step procedure might help.
You need three files from https://github.com/FreeCAD/FreeCAD-macr ... ctCreation, BoxCreator.FCMacro and in the boxcreator folder __init__.py and boxcreator.py.
In the screenshot of your Macros folder you had two of the files (in the wrong location) but you first need to create a subfolder of the Macro folder called boxcreator and copy the __init__.py and boxcreator.py files into it. Only the BoxCreator.FCMacro file should be in the Macro folder but that's the one you Execute.
Syres wrote: Sun Jun 30, 2019 10:53 amI believe the reason for new users (or those of us who never had the macro) not seeing macros such as this one is that they must have an entry in the Wiki
There must be another reason, because I do see it in the Addonmanager's list.
