boxcreator on Freecad 0.18
Syres
Re: boxcreator on Freecad 0.18
Post by Syres »
chrisb wrote: Sun Jun 30, 2019 12:53 pm
Syres wrote: Sun Jun 30, 2019 10:53 amI believe the reason for new users (or those of us who never had the macro) not seeing macros such as this one is that they must have an entry in the Wiki
There must be another reason, because I do see it in the Addonmanager's list.
I've read the code more thoroughly and the first step, it tries to use GitPython which I would guess at least 75% of Windows users wouldn't have installed and then it uses the Wiki so I'm guessing you are running GitPython. The code section in addonmanager_workers.py I'm referring to is:
    def run(self):
        """Populates the list of macros"""
        self.retrieve_macros_from_git()
        self.retrieve_macros_from_wiki()
        [self.add_macro_signal.emit(m) for m in sorted(self.macros, key=lambda m: m.name.lower())]
        if self.macros:
            self.info_label_signal.emit(translate('AddonsInstaller', 'List of macros successfully retrieved.'))
        self.progressbar_show.emit(False)
        self.stop = True
    def retrieve_macros_from_git(self):
        """Retrieve macros from FreeCAD-macros.git
        Emits a signal for each macro in
        https://github.com/FreeCAD/FreeCAD-macros.git
        try:
            import git
        except ImportError:
            self.info_label_signal.emit("GitPython not installed! Cannot retrieve macros from Git")
            FreeCAD.Console.PrintWarning(translate('AddonsInstaller', 'GitPython not installed! Cannot retrieve macros from git')+"\n")
            return
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17171 (Git)
Hash: d19470a9711ea604f3ca6c93e46afadf64d5bb87
Python version: 3.6.8
Qt version: 5.12.1
I'm on a Mac and have indeed Git installed. So I think you are right with your assumption.
UR_
Post by UR_ »
windows conda builds and LP 12.1.2 builds have gitpython in their package
jmaustpc
Post by jmaustpc »
Syres wrote: Mon Jul 01, 2019 10:34 am it tries to use GitPython
Now that you mention it, Yorik did say something about python-git, I had forgotten.
Package name in Ubuntu is python-git for Python2 and python3-git for Python 3.
christi
Post by christi »
TheMarkster wrote: Mon Jul 01, 2019 7:10 am That's a neat macro. Only one problem -- those box joints are going to be mighty tight come assembly time. Of course, if you print with ABS and use acetone it will probably still be able to go together as the acetone dissolves some of the material.
You can use the 3D Offset tool from the Part workbench to shrink the sides of the box. Enter a negative value for offset parameter.
TheMarkster
Post by TheMarkster »
UR_ wrote: Sun Jun 30, 2019 2:52 pm
Edit:
yorik wrote: *ping*
i had to add to ...\Mod\AddonManager\addonmanager_utilities.py, line 27
import shutil
to make install of macro working
I already have another trivial addonmanager bugfix PR pending. I will add UR_'s fix for this bug to it, too.
https://github.com/FreeCAD/FreeCAD/pull/2304
TheMarkster
christi wrote: Mon Jul 01, 2019 4:07 pm You can use the 3D Offset tool from the Part workbench to shrink the sides of the box. Enter a negative value for offset parameter.
Thank you. Yes, that is a good tool for this. I have another way that has more work involved, but has the advantage of allowing us better control over which faces get cut into.
This macro makes extrude compatible face objects from all selected faces. To use is very simple (though somewhat tedious with many faces). Just select your faces, then run the macro.
CopyFaces Macro, by TheMarkster
Creates a simple non-parametric face object from each selected face.  This face object can be extruded.
Can even extrude all of them in one go via Part -> Extrude.  It is suggested to
make the Extrude symmetric for more predictable results.
import FreeCAD
import Draft
selobj = FreeCAD.Gui.Selection.getSelectionEx()
if len(selobj)>=1:
    faces=FreeCAD.Gui.Selection.getSelectionEx()[0].SubObjects
else:
    FreeCAD.Console.PrintError("Select some faces and try again.")
for f in faces:
    w = Draft.makeWire(f)
    face = Draft.downgrade(App.ActiveDocument.ActiveObject)
You will find in the tree view now some new objects Face, Face001, Face002, etc. Select them in the tree and run the Part -> Extrude on them. Set symmetric checkbox so you don't get some of the faces extruded in the wrong direction from what you intend. Fuse the Extrude objects, then cut the Fuse from the object to trim away some of each face (or Fuse to the object if you want to pad the faces instead of cut them).
In the video notice I only select the interior faces on the side because I don't want to cut deeper that other face. I just want to more easily be able to assemble the box.
Also note that I have my settings to have refine turned off, so where the cut is made there are some tiny extra faces showing. These won't be there if you refine set to true.
phpBB [video]
harlekin
Post by harlekin »
This is the versione i work with:
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
thank you again
blue0cean
Box Creator Script
Post by blue0cean »
cool, thanks. Works.
Unfortunately, a bug has crept in. Partitions can only be inserted in x or y. If you started with x, the following error occurs when inserting the y wall:
<Exception> Wire is not closed.
155.123 <App> Document.cpp (3738): Failed to recompute Unnamed # bottom: Wire is not closed.
Recompute failed! Please check report view.
or is that not allowed?
OS: Windows 10 (10.0)
Version: 0.19.21775 (Git)
Hash: 1f741aa511e898849e46ed14515fce416fe32acb
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
2020-07-03 11_15_41-Window.jpg (197.48 KiB) Viewed 928 times
BoxCreator.FCStd
(197.09 KiB) Downloaded 51 times
christi
Re: Box Creator Script
Post by christi »
blue0cean wrote: Fri Jul 03, 2020 9:21 am cool, thanks. Works.
The problem are overlapping holes in the bottom.
While I do not find a solution for this, you can delete one of the holes manually, or use a different offset for the compartment to get the hole generated in between the other holes.
