Another Assembly A2plus V0.4.23 question
un1corn
Postby un1corn » Tue Jul 02, 2019 7:30 am
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
This seems a strange happening, perhaps someone can enlighten me.
Making a water pump which involves ball valves, I tried to import into A2+ a sphere as a file "sphere_part" but it does not appear in the assembly, I then tried to import a drawn sphere file "Sphere_drawn" and this also would not appear in the assembly.
However I can import/insert a sphere directly from PartWB into the assembly file !
There should be one sphere 10mm above and one sphere 10mm below the visible sphere in the attached file Sphere_placement.JPG, I include the assembly, drawn and part sphere files I have used both of the imported file methods in FC V0.16 many times in the past never had a problem.
As can be seen 3 spheres appear in the model tree........
Not quite sure what to make of this, is this intentional, has anyone else experienced this problem?
Sphere_drawn.FCStd
(7.28 KiB) Downloaded 7 times
Sphere_part.FCStd
(2.92 KiB) Downloaded 7 times
sphere_placement.FCStd
(4.61 KiB) Downloaded 7 times
kbwbe
Re: Another Assembly A2plus V0.4.23 question
Postby kbwbe » Tue Jul 02, 2019 8:20 pm
Hi @unicorn,
this was a small bug which i just fixed. Please update your A2plus WB to version v0.4.25.
KBWBE
latest release: v0.4.42b, installable via FreeCAD's addon manager
un1corn
Postby un1corn » Wed Jul 03, 2019 2:07 pm
Thank you KBWBE, I will update ASAP.
Any possibilities of an assembly overlap checker being added at a future date?
I am using A2 assembly checker in V18, I just have to ignore the "No module named "objectProxy"" message and the checker works fine.
un1corn
Postby un1corn » Wed Jul 03, 2019 2:37 pm
Hi KBWBE. Have updated to A2+V0.4.25, unfortunately in my case at least, the problem persists, I even tried adding a Body to contain the imported files without success. I can still import a primitive sphere directly into an assembly file, attached latest try (using previous files).
Theoretically there should be six spheres on the screen.
kbwbe
Postby kbwbe » Wed Jul 03, 2019 3:47 pm
Hi @unicorn,
for me it is working and i can directly import a sphere made by Part WB and a sphere made by PartDesign WB. Please have a look at my screenshot:
My freecad version ist:
OS: Linux Mint 18.3 Sylvia
Version: 0.18.1.
Python version: 2.7.12
The import was not working before the last fix. But now it works. (At least on my side). I am wondering why it is not working for you.
KBWBE
un1corn
Postby un1corn » Thu Jul 04, 2019 5:52 am
Thanks KBWBE for having another look at this, has anyone else reported having a similar issue?
I even tried running V0.18 as Administrator as V0.16 will only run that way on my PC , still no luck.
Attached snip of the same exercise in V0.16 with Assembly2 no problems encountered...........
This is my version FC
Qt version: 5.6.2
Sphere_Test_in FC V0.16_using A2.JPG (105.44 KiB) Viewed 184 times
easyw-fc
Postby easyw-fc » Thu Jul 04, 2019 8:27 am
would you mind to try with the solid option checked
un1corn
Postby un1corn » Thu Jul 04, 2019 11:39 am
Solved.
Thank you "easyw-fc" very much for your input which has solved the issue I was having.
I have to confess I did not look in the new A2+ preferences.
Attached resulting snips.
Thanks again.
