Chris
The problem is that what you see is not what you modeled. The tip of Body is not MultiTransform but LinearPattern - which is exactly what the clone represents Once you make MultiTransform the tip of Body the clone (and Path) do the right thing.Erich Schulz wrote: ↑Tue Jul 02, 2019 7:34 am Firstly when I a make the job the model clone fails to fully represent the multi-select (so rather than having a grid of holes, the path model onlyl has the first column)
You have to hide both, the Job and the operation for it to disappear - assuming hiding is all you wanted. If you want to disable it change the value of Active to False and it also disappears.Secondly at one point I had a very hard time getting one of my paths to dissapear - setting the operation to invisible or even the job to invisible failed to hide it. Eventually I saved and reopened the file a few times and the paths dissapeared.
