Gentoo overlay waebbl for freecad
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
clytle374
Post by clytle374 »
Since I was asked to post here my results, here is what I have found. Note that I've been running Freecad from git for a long time, so no guarantee on all dependencies being met.
Package media-gfx/freecad-0.18.2-r1 seems to work without any build or run issues.
The media-gfx/freecad-9999 is failing on my system. Seems to be easy fixes to get it working. I've filed a bug report and what fixed mine (Not that I know what I'm doing, or it was the right way). When build it needs prefaced with to run. Probably only on nvidia systems.
LD_PRELOAD=/usr/lib64/opengl/nvidia/lib/libGL.so FreeCAD
General howto install on Gentoo:
First you need to install Layman. It handles the overlays, overlays allow the adding of unofficial packages into Portage so they can be easily emerged.
emerge --ask app-portage/layman
Should be sufficient to get layman running.
Now you need to add the waebbl overlay to the system.
layman -a waebbl
Now when you run emerge there will be 2 Freecad packages available.
media-gfx/freecad-0.18.2-r1 and media-gfx/freecad-9999
They will be masked by portage, so you will have to allow them specifically to be installed by editing /etc/portage/package.accept_keywords and adding one of the 2 following lines.
For version 18.2 add the following
=media-gfx/freecad-0.18.2-r1 ~amd64
For the development version
=media-gfx/freecad-9999 **
Now
emerge --ask freecad
should install freecad.
Let me know if I made any errors here.
Thanks
Cory
clytle374
Re: Gentoo overlay waebbl for freecad
Post by clytle374 »
Is now fixed!
Post by Kunda1 »
clytle374 wrote: Fri Jul 05, 2019 11:02 am =media-gfx/freecad-9999 **
Is now fixed!
Nice, Upstream Downstream (technically more accurate) accepted your changes? URL ?
clytle374
Post by clytle374 »
Kunda1 wrote: Fri Jul 05, 2019 1:21 pm
Is now fixed!
They made a change to a path. Not my change, they did it the right way. Lol
The other issue fixed itself. It was a path issue with OCC.
https://github.com/waebbl/waebbl-gentoo
waebbl
Post by waebbl »
clytle374 wrote: Fri Jul 05, 2019 9:41 pm
Uh wow :o Thanks for advertising my overlay @clytle374
clytle374
Post by clytle374 »
waebbl wrote: Mon Jul 29, 2019 4:49 pm
You're welcome. I'm still cooking from git at the moment because that is what I'm used to. I do use the opencascade overlay of yours since unlike freecad opnecascade doesn't run in place without being installed.
Thanks for your support of freecad.
Cory
Post by Kunda1 »
clytle374 wrote: Sun Oct 20, 2019 10:06 pm Thanks for your support of freecad.
I 2nd this :point_up_2:
