Draft Layers
nic
Re: Draft Layers
Post by nic »
Probably not, and it wouldn't help with the problem: "collect all {obj} and put them in a layer", {obj} being one of {sketches, walls, part, whatever}.
bitacovir
Re: Draft Layers
Post by bitacovir »
In my case, the layer's icon doesn't show any color.
Also, one question. How do you create a new layer in the Layers group?
OS: Windows 10 (10.0)
Version: 0.19.16945 (Git)
Hash: d818a9638424a934bd9da74d187a1af4cb773f05
Python version: 3.6.8
Qt version: 5.12.1
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: Draft Layers
Post by yorik »
Layers go automatically into the layer group.
I found that the tree doesn't request new icons all the time. Only at certain moments, for ex. when hiding/showing layers. Not sure yet how to attack that issue...
Chris_G
Re: Draft Layers
Post by Chris_G »
Hi Yorik,
I am glad to see Layers implemented.
I made an experiment about this.
I have not been able to solve the "update icon" issue.
It would be really great to be able to force icon update.
This little icon is a very "UX friendly" way to communicate some information to the user.
I suppose it means something like adding a "updateIcon" method to the viewprovider ???
I have never been much outside PartWB code, so I don't know all the mechanics up there :D .
Re: Draft Layers
Post by yorik »
Oh wow, I hadn't seen you had done something similar...
Will have a better look, there might be stuff to merge between the two.
For the icons, basically, the getIcon() method accepts two possibilities: a file path to an image, or XPM data. So I made another function that produces an XPM icon, simply by "drawing" it with Qt painting tools: https://github.com/FreeCAD/FreeCAD/blob ... er.py#L211
and then caching the XPM data so the getIcon() can serve it when needed without the need to recalculate it.
But indeed I haven't been able to force an icon recompute...
wandererfan
Re: Draft Layers
Post by wandererfan »
yorik wrote: Sun Jun 16, 2019 3:02 am But indeed I haven't been able to force an icon recompute...
Don't have a Python example, but here is how I change the icon for the various dimension types. Might spark something for you.
void ViewProviderDimension::updateData(const App::Property* p)
    if (p == &(getViewObject()->Type)) {
        if (getViewObject()->Type.isValue("DistanceX")) {
            sPixmap = "TechDraw_Dimension_Horizontal";
        } else if (getViewObject()->Type.isValue("DistanceY")) {
            sPixmap = "TechDraw_Dimension_Vertical";
        } else if (getViewObject()->Type.isValue("Radius")) {
            sPixmap = "TechDraw_Dimension_Radius";
        } else if (getViewObject()->Type.isValue("Diameter")) {
            sPixmap = "TechDraw_Dimension_Diameter";
        } else if (getViewObject()->Type.isValue("Angle")) {
            sPixmap = "TechDraw_Dimension_Angle";
        } else if (getViewObject()->Type.isValue("Angle3Pt")) {
            sPixmap = "TechDraw_Dimension_Angle3Pt";
    ViewProviderDrawingView::updateData(p);
RatonLaveur
Re: Draft Layers
Post by RatonLaveur »
Hello gents,
the implementation of layers seems really cool. Coming from the laser cutting point of view, this is exactly the method needed to have control over more complex .dxf cutting files.
in a more CAD oriented aspect, my experience with other CAD packages such as Siemens NX, shows that using layers is also very useful within a single part design, where layers can be used to separate or suppress the skeleton and master sketches. I'm sure down the line this will enable a part design workflow that will not phase new people coming from this background, which definitely propels FreeCAD front and center.
Just a positive thought on your work and tribulations.
Roy_043
Re: Draft Layers
Post by Roy_043 »
Layers now have a Line Color and a Shape Color. I wonder if Point Color should be added (Draft_Point objects).
rmz
Re: Draft Layers
Post by rmz »
Hello,
I tried to use the new Draft layer feature but it does not work as described by Yorik at the beginning of this thread as the layer seems to "consume" the object. I did the following:
  • Open an existing document which has a group tree (Site --> Building --> Floor --> objests ..)
  • Change to the Draft bench
  • Create some layers
  • Changed to the BIM bench
  • Dragged an object from a group to a layer with the mouse
Dragging the object to the layer removes the object from the original parent group which should not be the case. In fact it renders the layer concept unusable for controlling the display. Am I doing something wrong, or did I misunderstand the purpose of layers?
This is the build information (but I don't think it matters):
OS: Ubuntu 20.04.1 LTS (MATE/mate)
Version: 0.19.22039 (Git) AppImage
Hash: 2bfc6301bc80c0344cbf13dbfe041fbd78cac93d
Python version: 3.8.2
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Thanks for all your work and engangement on FreeCAD, it is really great!
-Rainer
paullee
Re: Draft Layers
Post by paullee »
rmz wrote: Sun Aug 16, 2020 4:04 pm
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
@yorik seems do not have proper access to the network recently, you may try to ping him so he may have a better idea which thread needs him
yorik wrote: Ping
BTW, the FC info is good to have for ease of debugging by developers.
