Calculation stops with such an error message
What cause can be considered
*INFO in gen3dnor: in some nodes opposite normals are defined
*ERROR in gen3dnor: more than 100 ?hell elements share the
same node
2.2: CalculiX execute error:
このようなエラーメッセージで計算が止まります
どんな原因が考えられるでしょうか
shell elements share the same node ?
Re: shell elements share the same node ?
seams some bad mesh. Difficault to say what caused the mesh to be bad. Would you post the FreeCAD file with mesh cleared?
Make sure to use 0.19 dev version if you gone work with FEM. See https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
