Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
hardeeprai wrote: Thu Jul 11, 2019 4:19 pm
You may do following:
1. Corners bars bent at 45 degrees to side.
2. Non-corner bars bent perpendicular to side
Above mean, all bars bent towards centre (almost) of section.
To implement this, I need to do changes in core functionality of rebar addon or recreate function makeLShapeRebar()
I will discuss about this with @amrit3701
In meantime, I created function for circular column reinforcement and can be found here.
Example:
from ColumnReinforcement import CircularColumn
CircularColumn.makeReinforcement(20, 20, 20, 50, 10, 16, True, 6)
Image:
CircularColumn.FCStd
(140.88 KiB) Downloaded 60 times
There is one problem in this:
When I select Host for rebars, then rebars will go out of column from bottom as in this image:
I am unable to identify the issue in this.
Thanks,
Suraj Dadral
Suraj Dadral wrote: Sat Jul 13, 2019 5:25 am
The issue has been resolved :) by setting placement of line (created using draft) before creating rebars. Related code snippet:
pl = FreeCAD.Placement()
pl.Rotation.Q = (0.5, 0.5, 0.5, 0.5)
for points in points_list:
    line = Draft.makeWire(
        points, placement=pl, closed=False, face=True, support=None
    rebar = Arch.makeRebar(structure, line, dia_of_straight_rebars, 1)
Related commit:
https://github.com/SurajDadral/FreeCAD- ... 631ff05cd1
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Mon Jul 15, 2019 8:15 am The issue has been resolved :) by setting placement of line (created using draft) before creating rebars. Related code snippet:
Related commit:
+1. Great! Today, I also tried to create rebar from draft wire manually and there I haven't seen this problem. So, I was also thinking that the issue is on your side, not the FreeCAD side.
Amritpal Singh
Github, Like my work, sponsor me!
Suraj Dadral
amrit3701 wrote: Mon Jul 15, 2019 5:10 pm
Yes, the problem was from my side.
I have created UI for circular column reinforcement. Now, user can create circular column reinforcement from ui.
Preview:
Please review and give your suggestions.
Thanks,
Post by yorik »
Looking good!
Post by bernd »
Suraj Dadral wrote: Tue Jul 16, 2019 5:33 pm
Preview:
Thanks,
For normal columns this is great, but I would use it for piles too. On piles the pitch changes. Means if for example the pile is 25 meters long. Since maximum reabar lenght is 15 meters there need to be some smaller pitch in the area where the straight rebars meet around the 12.5 m.
BTW: GUI in Allplan is like yours. The changes in pitch is not possible there either.
Suraj Dadral
bernd wrote: Wed Jul 17, 2019 2:21 pm
Thanks @bernd for your feedback.
I have added this to wish list here.
I will try implement it during gsoc period.
Thanks,
Suraj Dadral
I have created function to edit circular column reinforcement. And implemented the same through ui.
Now, user can create and edit circular column reinforcement from ui.
Related PR is here: https://github.com/amrit3701/FreeCAD-Re ... nt/pull/29
Thanks,
Suraj Dadral
hardeeprai wrote: Thu Jul 11, 2019 4:24 pm
Suraj Dadral wrote: Thu Jul 11, 2019 9:21 amI also discussed this with my civil engineer friends and according to them, diameter of all ties in column is equal in 99% cases.
Take it 100%
In below image, in case of two ties column reinforcement, do we keep "Bent Angle" and "Extension Factor" of all the ties different or they will also be same?
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Thu Jul 18, 2019 1:08 pm In below image, in case of two ties column reinforcement, do we keep "Bent Angle" and "Extension Factor" of all the ties different or they will also be same?
I think bent angle and extension factor should be same for all ties in the column because all ties have same diameter.
Amritpal Singh
