Good evening,
Imagine you draw a sketch in sketcher. The shown one is just an simplified example sometimes there are x10 of constraints.
If one adds to many constraints than they get removed automatically as happened in the shown example when adding the horizontal constraints "50mm".
But sometimes its nice to temporarily add more constraints and deselect the unused ones afterwards. Originally, I expected that if I deselect "Auto Remove Redundants" I would be able to add the "50mm" constraint and simply get a warning that there are redundant constraints. But that did not work out. Is this a bug or do I simply not get the working principle right?
So here comes my feature-request:
Much more helpful for the user would be a message informing that there are redundant constraints while asking if the new one or the old and redundant one should be kept. The other one could be switched to "reference mode".
Thanks in advance,
BR,
HoWil
