Adaptive Path/CAM Operation
Re: Adaptive Path/CAM Operation
Tried the macro, alas here the write command fails:
sys.stdout.write("AP: {}\n".format(path))
  File "<input>", line 3, in <module>
NameError: name 'sys' is not defined
OS: macOS High Sierra (10.13)
Version: 0.19.16933 (Git)
Hash: 4494d384a6b7e183dd4ae12baadfcf6972039c45
Python version: 3.7.3
Qt version: 5.9.7
sliptonic
Post by sliptonic »
Add an
import sys
At the beginning
Here is my output. The values look reasonable compared to yours. You may note that even in the first path there are deviations of ~0.2 - far too much for the common rounding issues.
I had observed such differences before, when I had the issues, and you didn't.
AP: (0, [(-49.99375, 44.74375), (-49.91875, 44.66875), (-49.8625, 44.58125), (-49.84375, 44.48125), (-49.225, 43.1625), (-48.74375, 42.51875), (-48.4, 42.2125), (-48.15625, 42.0375), (-47.85, 41.875), (-47.50625, 41.7625), (-47.2, 41.63125), (-46.45, 41.34375), (-45.66875, 41.1625), (-44.90625, 41.11875), (-44.55, 41.13125), (-43.7125, 41.225), (-42.9375, 41.4375), (-42.4, 41.6125), (-41.8, 41.8875), (-41.375, 42.125), (-40.9125, 42.44375), (-40.48125, 42.80625), (-40.05, 43.11875), (-39.475, 43.675), (-38.95, 44.23125), (-38.46875, 44.86875), (-38.1625, 45.31875), (-37.58125, 46.35625), (-37.025, 48.025), (-36.46875, 52.525), (-36.63125, 55.05625), (-37.0625, 56.6375), (-37.425, 57.425), (-38.06875, 58.36875), (-39.1, 59.58125), (-39.63125, 60.175), (-40.23125, 60.7), (-40.7875, 61.13125), (-41.33125, 61.525), (-42.0125, 61.93125), (-43.18125, 62.5375), (-43.64375, 62.65625), (-44.01875, 62.69375), (-44.10625, 62.73125), (-45.5125, 63.06875), (-50.95, 63.4875), (-53.66875, 63.26875), (-55.35625, 62.83125), (-55.98125, 62.5375), (-56.21875, 62.3625), (-56.2875, 62.29375), (-56.375, 62.25625), (-56.5375, 62.14375), (-57.675, 61.54375), (-58.3625, 61.14375), (-59.0, 60.6625), (-59.4625, 60.2625), (-59.9125, 59.84375), (-60.44375, 59.24375), (-60.85625, 58.70625), (-61.25, 58.125), (-61.6875, 57.5375), (-62.18125, 56.6625), (-62.54375, 55.71875), (-62.83125, 54.51875), (-63.18125, 51.51875), (-63.1, 48.21875), (-62.875, 46.51875), (-62.54375, 45.425), (-61.93125, 44.1125), (-61.63125, 43.36875), (-61.3, 42.6375), (-60.8875, 41.95), (-60.025, 40.66875), (-59.5125, 40.04375), (-58.975, 39.44375), (-58.5, 38.79375), (-57.34375, 37.53125), (-57.0125, 37.2625), (-56.74375, 37.10625), (-55.90625, 36.33125), (-55.80625, 36.3125), (-37.30625, 36.35625), (-36.70625, 36.4375), (-36.5125, 36.5), (-36.35625, 36.625), (-36.31875, 36.71875), (-36.3125, 43.5625)])
AP: (0, [(-36.3125, 43.5625), (-36.325, 43.66875)])
AP: (1, [])
AP: (0, [(-36.33125, 43.6), (-36.325, 43.44375), (-36.3125, 43.6625)])
AP: (0, [(-36.3125, 43.6625), (-36.3125, 44.6)])
AP: (0, [(-36.3125, 44.6), (-36.35, 45.11875), (-36.4125, 45.6375), (-36.525, 46.14375), (-36.68125, 46.6375), (-37.0875, 47.6375), (-37.2875, 48.15625)])
AP: (1, [])
AP: (0, [(-37.4375, 48.68125), (-37.5375, 49.2125), (-37.5875, 49.74375), (-37.59375, 50.2625), (-37.5375, 50.76875), (-37.4125, 51.25625), (-37.2375, 51.725), (-36.83125, 52.675), (-36.65625, 53.1625), (-36.525, 53.6625), (-36.425, 54.175), (-36.3125, 55.2125)])
AP: (0, [(-36.3125, 55.2125), (-36.3125, 63.18125), (-36.325, 63.275), (-36.4, 63.45), (-36.45625, 63.53125), (-36.61875, 63.63125), (-36.70625, 63.66875), (-45.05, 63.68125)])
AP: (0, [(-45.05, 63.68125), (-45.56875, 63.6375), (-46.0875, 63.5625), (-46.59375, 63.45), (-47.6, 63.16875)])
AP: (1, [])
AP: (0, [(-48.1125, 63.08125), (-48.625, 63.0625), (-49.13125, 63.125), (-50.65, 63.48125), (-51.1625, 63.5625), (-52.20625, 63.68125)])
AP: (0, [(-52.20625, 63.68125), (-63.26875, 63.61875), (-63.45625, 63.575), (-63.5375, 63.51875), (-63.6, 63.44375), (-63.68125, 63.25625), (-63.68125, 36.75625), (-63.60625, 36.5625), (-63.54375, 36.475), (-63.4625, 36.40625), (-63.26875, 36.31875), (-61.76875, 36.3125)])
AP: (0, [(-61.76875, 36.3125), (-61.24375, 36.35), (-60.725, 36.4125), (-60.21875, 36.525), (-59.71875, 36.68125), (-59.24375, 36.88125), (-58.7875, 37.125), (-58.35, 37.4125)])
AP: (1, [(-57.9375, 37.73125), (-57.54375, 38.08125), (-56.4125, 39.20625), (-39.45625, 56.95625)])
AP: (0, [(-39.0125, 57.41875), (-37.73125, 58.8), (-37.34375, 59.25), (-37.0, 59.7), (-36.7, 60.15625), (-36.44375, 60.625), (-36.23125, 61.10625), (-36.06875, 61.6), (-35.95, 62.10625), (-35.7875, 63.14375)])
AP: (0, [(-35.7875, 63.14375), (-35.79375, 63.24375), (-35.83125, 63.4625), (-35.9125, 63.65625), (-36.05, 63.85), (-36.26875, 64.04375), (-36.425, 64.11875), (-36.64375, 64.19375), (-36.9, 64.2125), (-63.24375, 64.2), (-63.46875, 64.1625), (-63.6625, 64.08125), (-63.86875, 63.925), (-64.04375, 63.725), (-64.11875, 63.56875), (-64.19375, 63.35), (-64.2125, 63.05625), (-64.2, 36.75), (-64.1625, 36.525), (-64.08125, 36.33125), (-63.9375, 36.1375), (-63.725, 35.95), (-63.56875, 35.875), (-63.35, 35.8), (-63.09375, 35.78125), (-37.025, 35.78125), (-36.70625, 35.8), (-36.525, 35.83125), (-36.33125, 35.9125), (-36.1375, 36.05625), (-35.95, 36.26875), (-35.8875, 36.4), (-35.8, 36.64375), (-35.78125, 36.9), (-35.7875, 63.15), (-35.7875, 63.14375)])
kreso-t
Post by kreso-t »
I finally managed to reproduce the problem using openSUSE 15.1Beta (in a VirtualBox)
OS: openSUSE Leap 15.1Beta
Version: 0.18.16117 (Git) AppImage
Branch: (HEAD detached at 0.18.2)
Python version: 3.6.7
Qt version: 5.6.2
fixing it now it should be the easier part...
BR,
K.
Thanks for working on it, I hope the best!
dubstar-04
Post by dubstar-04 »
I've been away from FreeCAD for a while, I've updated FreeCAD and this is reproduceable.
File attached incase its any use.
OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu)
Version: 0.19.
Qt version: 5.12.2
DizzyBlank2-CAM.fcstd
(274.64 KiB) Downloaded 56 times
kreso-t
Post by kreso-t »
The issue should be fixed now.
using openSUSE Leap 15.1Beta where it consistently appeared
before applying fix:
the same model with fix applied:
BR,
Kresimir
Great!
dubstar-04
Working well for me too!
Thank you,
Dan
