I plan to build a new pulling tractor modeled after a slingshot dragster.
The driver can be downloaded from here
Mini Rod Pulling Tractor
Sample of work
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Qt version: 5.6.2
Re: Mini Rod Pulling Tractor
Hi LiveWire and welcome to the forum! Our forum member japie has done something similar:
https://forum.freecadweb.org/viewtopic.php?f=24&t=12695
Find your user.cfg and system.cfg files : Macro_findConfigFiles
Imperial system makes no sense, go metric ! ! !
Interestingbejant wrote: ↑Tue Jul 16, 2019 4:40 amHi LiveWire and welcome to the forum! Our forum member japie has done something similar:
Sample of work
Qt version: 5.6.2
Qt version: 5.6.2
I downloaded a model that I believe was intended to be a 3D printed movable figure. I setup constraints using A2Plus workbench to tie the pieces together and can change the angles.
You can download the FreeCAD file here: https://grabcad.com/library/configurable-driver-1
Sample of work
Qt version: 5.6.2
Qt version: 5.6.2
Would it be possible to upload the file to a hoster where no registration is necessary?
- arturromarr
A very interesting project. when will the plans become reality?
- Pauvres_honteux
A suggestion: Make human
Last time I used it I had to utilize Blender to scale the model and reduce the node count. A bit fiddly, but worked for my purpose.
