cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh && /usr/bin/cmake -E cmake_link_script CMakeFiles/Driver.dir/link.txt --verbose=1
/usr/bin/x86_64-pc-linux-gnu-g++ -fPIC -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -Wl,-O1 -Wl,--as-needed -shared -Wl,-soname,libDriver.so -o ../../../lib/libDriver.so CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o -L/usr/lib64/opencascade-7.3.0/lib64 -Wl,-rpath,/usr/lib64/opencascade-7.3.0/lib64: -lmpi_cxx -lmpi /usr/lib64/libTKSTL.so.11.0.0 /usr/lib64/libTKBin.so.11.0.0 /usr/lib64/libTKFeat.so.11.0.0 /usr/lib64/libTKXDESTEP.so.11.0.0 /usr/lib64/libTKXDEIGES.so.11.0.0 /usr/lib64/libTKMeshVS.so.11.0.0 /usr/lib64/libTKBinL.so.11.0.0 /usr/lib64/libTKSTEP.so.11.0.0 /usr/lib64/libTKSTEP209.so.11.0.0 /usr/lib64/libTKSTEPAttr.so.11.0.0 /usr/lib64/libTKSTEPBase.so.11.0.0 /usr/lib64/libTKIGES.so.11.0.0 /usr/lib64/libTKOffset.so.11.0.0 /usr/lib64/libTKFillet.so.11.0.0 /usr/lib64/libTKBool.so.11.0.0 /usr/lib64/libTKXSBase.so.11.0.0 /usr/lib64/libTKXCAF.so.11.0.0 /usr/lib64/libTKCAF.so.11.0.0 /usr/lib64/libTKBO.so.11.0.0 /usr/lib64/libTKPrim.so.11.0.0 /usr/lib64/libTKLCAF.so.11.0.0 /usr/lib64/libTKCDF.so.11.0.0 /usr/lib64/libTKV3d.so.11.0.0 /usr/lib64/libTKMesh.so.11.0.0 /usr/lib64/libTKHLR.so.11.0.0 /usr/lib64/libTKService.so.11.0.0 /usr/lib64/libTKShHealing.so.11.0.0 /usr/lib64/libTKTopAlgo.so.11.0.0 /usr/lib64/libTKGeomAlgo.so.11.0.0 /usr/lib64/libTKBRep.so.11.0.0 /usr/lib64/libTKGeomBase.so.11.0.0 /usr/lib64/libTKG3d.so.11.0.0 /usr/lib64/libTKG2d.so.11.0.0 /usr/lib64/libTKMath.so.11.0.0 /usr/lib64/libTKernel.so.11.0.0 -lpthread -ldl -lm /usr/lib/libSM.so /usr/lib/libICE.so /usr/lib/libX11.so /usr/lib/libXext.so /usr/lib/libGL.so /usr/lib/libGLU.so /usr/lib/libfreetype.so
/usr/lib/gcc/x86_64-pc-linux-gnu/9.1.0/../../../../x86_64-pc-linux-gnu/bin/ld: /usr/lib/libSM.so: error adding symbols: file in wrong format
/usr/lib/libSM.so
/usr/lib/libICE.so
/usr/lib/libX11.so
/usr/lib/libXext.so
/usr/lib/libGL.so
/usr/lib/libGLU.so
here are the files of libSM library, just to show what is installed:
# equery files libSM
* Searching for libSM ...
* Contents of x11-libs/libSM-1.2.3:
/usr
/usr/include
/usr/include/X11
/usr/include/X11/SM
/usr/include/X11/SM/SM.h
/usr/include/X11/SM/SMlib.h
/usr/include/X11/SM/SMproto.h
/usr/lib
/usr/lib/libSM.so -> libSM.so.6.0.1
/usr/lib/libSM.so.6 -> libSM.so.6.0.1
/usr/lib/libSM.so.6.0.1
/usr/lib/pkgconfig
/usr/lib/pkgconfig/sm.pc
/usr/lib64
/usr/lib64/libSM.so -> libSM.so.6.0.1
/usr/lib64/libSM.so.6 -> libSM.so.6.0.1
/usr/lib64/libSM.so.6.0.1
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/sm.pc
/usr/share
/usr/share/doc
/usr/share/doc/libSM-1.2.3
/usr/share/doc/libSM-1.2.3/AUTHORS.bz2
/usr/share/doc/libSM-1.2.3/ChangeLog.bz2
/usr/share/doc/libSM-1.2.3/README.bz2
* Package: media-gfx/freecad-9999
* Repository: fordfrog
* Maintainer: fordfrog@gentoo.org
* USE: abi_x86_64 amd64 elibc_glibc freecad_modules_addonmgr freecad_modules_arch freecad_modules_complete freecad_modules_draft freecad_modules_drawing freecad_modules_fem freecad_modules_idf freecad_modules_image freecad_modules_import freecad_modules_inspection freecad_modules_material freecad_modules_mesh freecad_modules_mesh_part freecad_modules_openscad freecad_modules_part freecad_modules_part_design freecad_modules_path freecad_modules_plot freecad_modules_points freecad_modules_raytracing freecad_modules_reverseengineering freecad_modules_robot freecad_modules_ship freecad_modules_show freecad_modules_sketcher freecad_modules_spreadsheet freecad_modules_start freecad_modules_surface freecad_modules_techdraw freecad_modules_test freecad_modules_tux freecad_modules_web freetype kernel_linux python_targets_python3_6 qt5 userland_GNU
* FEATURES: network-sandbox preserve-libs sandbox userpriv usersandbox
* Using following Fortran compiler:
* F77: x86_64-pc-linux-gnu-gfortran
* FC: x86_64-pc-linux-gnu-gfortran
>>> Unpacking source...
* Repository id: FreeCAD_FreeCAD.git
* To override fetched repository properties, use:
* EGIT_OVERRIDE_REPO_FREECAD_FREECAD
* EGIT_OVERRIDE_BRANCH_FREECAD_FREECAD
* EGIT_OVERRIDE_COMMIT_FREECAD_FREECAD
* EGIT_OVERRIDE_COMMIT_DATE_FREECAD_FREECAD
* Fetching https://github.com/FreeCAD/FreeCAD.git ...
git fetch https://github.com/FreeCAD/FreeCAD.git +HEAD:refs/git-r3/HEAD
Auto packing the repository in background for optimum performance.
See "git help gc" for manual housekeeping.
git symbolic-ref refs/git-r3/media-gfx/freecad/0/__main__ refs/git-r3/HEAD
* Checking out https://github.com/FreeCAD/FreeCAD.git to /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 ...
git checkout --quiet refs/git-r3/HEAD
GIT update -->
repository: https://github.com/FreeCAD/FreeCAD.git
at the commit: be1cc9ca9f27750166241310a41693601cbb862d
>>> Source unpacked in /var/tmp/portage/media-gfx/freecad-9999/work
>>> Preparing source in /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 ...
* Applying freecad-9999-install-paths.patch ... [ ok ]
* Hardcoded definition(s) removed in CMakeLists.txt:
* set(CMAKE_INSTALL_PREFIX ${CMAKE_BINARY_DIR}/install CACHE PATH "Installa
* set(CMAKE_INSTALL_PREFIX "/usr/lib${LIB_SUFFIX}/freecad" CACHE PATH "Inst
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 ...
>>> Working in BUILD_DIR: "/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build"
cmake -C /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/gentoo_common_config.cmake -G Unix Makefiles -DCMAKE_INSTALL_PREFIX=/usr -DOCC_INCLUDE_DIR=/usr/lib64/opencascade-7.3.0/inc -DOCC_LIBRARY_DIR=/usr/lib64/opencascade-7.3.0/lib64 -DCMAKE_INSTALL_DATADIR=/usr/share/freecad-9999 -DCMAKE_INSTALL_DOCDIR=/usr/share/doc/freecad-9999 -DCMAKE_INSTALL_INCLUDEDIR=/usr/include/freecad-9999 -DCMAKE_INSTALL_PREFIX=/usr/lib64/freecad -DFREECAD_USE_EXTERNAL_KDL=ON -DBUILD_QT5=yes -DBUILD_GUI=yes -DBUILD_FREETYPE=yes -DOPENMPI_INCLUDE_DIRS=/usr/include/ -DBUILD_ADDONMGR=ON -DBUILD_ARCH=ON -DBUILD_ASSEMBLY=OFF -DBUILD_COMPLETE=ON -DBUILD_DRAFT=ON -DBUILD_DRAWING=ON -DBUILD_FEM=ON -DBUILD_IDF=ON -DBUILD_IMAGE=ON -DBUILD_IMPORT=ON -DBUILD_INSPECTION=ON -DBUILD_JTREADER=OFF -DBUILD_MATERIAL=ON -DBUILD_MESH=ON -DBUILD_MESH_PART=ON -DBUILD_OPENSCAD=ON -DBUILD_PART=ON -DBUILD_PART_DESIGN=ON -DBUILD_PATH=ON -DBUILD_PLOT=ON -DBUILD_POINTS=ON -DBUILD_RAYTRACING=ON -DBUILD_REVERSEENGINEERING=ON -DBUILD_ROBOT=ON -DBUILD_SANDBOX=OFF -DBUILD_SHIP=ON -DBUILD_SHOW=ON -DBUILD_SKETCHER=ON -DBUILD_SMESH=OFF -DBUILD_SPREADSHEET=ON -DBUILD_START=ON -DBUILD_SURFACE=ON -DBUILD_TECHDRAW=ON -DBUILD_TEMPLATE=OFF -DBUILD_TEST=ON -DBUILD_TUX=ON -DBUILD_WEB=ON -DCMAKE_BUILD_TYPE=Gentoo -DCMAKE_TOOLCHAIN_FILE=/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/gentoo_toolchain.cmake /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999
loading initial cache file /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/gentoo_common_config.cmake
-- The C compiler identification is GNU 9.1.0
-- The CXX compiler identification is GNU 9.1.0
-- Check for working C compiler: /usr/bin/x86_64-pc-linux-gnu-gcc
-- Check for working C compiler: /usr/bin/x86_64-pc-linux-gnu-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/x86_64-pc-linux-gnu-g++
-- Check for working CXX compiler: /usr/bin/x86_64-pc-linux-gnu-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Compiler: GNU, version: 9.1.0
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: /usr/lib64/freecad
-- datadir: /usr/share/freecad-9999
-- docdir: /usr/share/doc/freecad-9999
-- includedir: /usr/include/freecad-9999
-- libdir: /usr/lib64/freecad/lib64
-- cmake: 3.14.5
-- Found PythonInterp: /var/tmp/portage/media-gfx/freecad-9999/temp/python3.6/bin/python (found version "3.6.8")
-- Found PythonLibs: /usr/lib64/libpython3.6m.so (found suitable exact version "3.6.8")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.70.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/lib64/libxerces-c.so
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.11")
-- PyCXX found:
-- Headers: /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src
-- Sources: /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/CXX
-- Version: 6.2.8
-- -- OpenCASCADE Community Edition has been found.
-- Found OCC: /usr/lib64/oce-0.18/../../include/oce (found version "6.9.1")
-- -- Found OCE/OpenCASCADE version: 6.9.1
-- -- OCE/OpenCASCADE include directory: /usr/lib64/oce-0.18/../../include/oce
-- -- OCE/OpenCASCADE shared libraries directory: /usr/lib64/opencascade-7.3.0/lib64
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/include
-- Found PkgConfig: x86_64-pc-linux-gnu-pkg-config (found version "0.29.2")
-- We guess that libmed was built using hdf5-serial version
-- Checking for one of the modules 'hdf5-serial'
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /usr/lib64/libhdf5.so;/usr/lib64/libz.so;/usr/lib64/libdl.so;/usr/lib64/libm.so (found version "1.10.5")
-- Checking for one of the modules 'ompi-cxx'
-- Found SWIG: /usr/bin/swig (found version "4.0.0")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.7", minimum required is "2.91.0")
-- Found Freetype: /usr/lib64/libfreetype.so (found version "2.10.1")
-- Found OpenGL: /usr/lib64/libGL.so
-- Found OpenGLU: /usr/lib64/libGLU.so
-- Checking for module 'Coin'
-- No package 'Coin' found
-- Coin3D libraries found
-- Found Spnav: /usr/lib64/libspnav.so
-- Shiboken2Config: Using default python: .cpython-36m-x86_64-linux-gnu
-- libshiboken built for Release
-- PYTHON_CONFIG_SUFFIX: .cpython-36m-x86_64-linux-gnu
-- -- matplotlib-2.2.4 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type: Gentoo
git
/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Build/Version.h.out written
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/BaseClassPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/BoundBoxPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/CoordinateSystemPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/PersistencePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/VectorPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/MatrixPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/RotationPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/PlacementPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/AxisPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/UnitPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Base/QuantityPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/DocumentPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/DocumentObjectPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/ExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/ExtensionContainerPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/DocumentObjectExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/GroupExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/DocumentObjectGroupPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/GeoFeaturePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/GeoFeatureGroupExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/OriginGroupExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/PartPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/ComplexGeoDataPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/PropertyContainerPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/App/MaterialPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Points/App/PointsPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Mesh/App/FacetPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Mesh/App/MeshPointPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Mesh/App/MeshPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcOfConicPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BodyBasePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ConicPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/CirclePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/EllipsePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/HyperbolaPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ParabolaPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/OffsetCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/GeometryPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/GeometryCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BoundedCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/LinePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/LineSegmentPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/PointPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BezierCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BSplineCurvePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/PlanePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ConePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/CylinderPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/SpherePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/ToroidPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BezierSurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/PlateSurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/PartFeaturePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/AttachExtensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Part2DObjectPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/AttachEnginePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/PartDesign/App/BodyPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/PartDesign/App/FeaturePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Sketcher/App/SketchPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Robot/App/TrajectoryPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Robot/App/WaypointPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Robot/App/RobotObjectPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Import/App/StepShapePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Fem/App/FemMeshPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/CommandPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/PathPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/ToolPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/TooltablePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/AreaPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/App/FeatureAreaPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- python36
-- found Boost: 1_70
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib64
-- Boost_LIBRARIES is: /usr/lib64/libboost_python36-mt.so
-- area module (for Path Workbench) will be installed to: /usr/lib64/freecad/lib64
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/Measure/App/MeasurementPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawPagePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawHatchPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawLeaderLinePy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Mod/TechDraw/App/DrawRichAnnoPy.cpp
Created file /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/doc/freecad.qch
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.15") found components: doxygen dot
-- Coin3D doc is not installed
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/DocumentPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/PythonWorkbenchPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/ViewProviderPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/ViewProviderDocumentObjectPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/WorkbenchPy.cpp
-- /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/Gui/SelectionObjectPy.cpp
Summary report
-- Python: [/var/tmp/portage/media-gfx/freecad-9999/temp/python3.6/bin/python] [.cpython-36m-x86_64-linux-gnu]
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 107000
-- XercesC: [/usr/lib64/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
-- PyCXX: [/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src]
-- OCC: 6.9.1 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
-- SMESH: build internal
-- MEDFile: [/usr/lib64/libmedC.so] [/usr/include]
-- HDF5: 1.10.5
-- VTK: 8.1.0
-- NETGEN: not enabled
-- SWIG: 4.0.0
-- Eigen3 3.3.7
-- Qt5Core: 5.12.3
-- Qt5Network: 5.12.3
-- Qt5Xml: 5.12.3
-- Qt5XmlPatterns: 5.12.3
-- Qt5Widgets: 5.12.3
-- Qt5PrintSupport: 5.12.3
-- Qt5OpenGL: 5.12.3
-- Qt5Svg: 5.12.3
-- Qt5UiTools: 5.12.3
-- Qt5Concurrent: 5.12.3
-- Qt5WebKitWidgets: 5.212.0
-- Shiboken2: 5.9.0 [/usr/lib64/cmake/Shiboken2-5.9.0] [/usr/include/shiboken2]
-- PySide2: 5.9.0 [/usr/include/PySide2]
-- PySide2Tools: [/usr/bin/pyside2-uic] [/usr/bin/pyside2-rcc]
-- Freetype: 2.10.1
-- OpenGLU: /usr/lib64/libGLU.so [/usr/lib64/libGLU.so][/usr/include]
-- Coin3D: [/usr/lib64/libCoin.so] [/usr/include]
-- SPNAV: [/usr/lib64/libspnav.so] [/usr/include]
-- Matplotlib: 2.2.4
-- Rift: not enabled (BUILD_VR)
-- Doxygen: not found
Now run 'cmake --build /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build' to build FreeCAD
-- <<< Gentoo configuration >>>
Build type Gentoo
Install path /usr/lib64/freecad
Compiler flags:
C -march=native -O2 -pipe
C++ -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe
Linker flags:
Executable -Wl,-O1 -Wl,--as-needed
Module -Wl,-O1 -Wl,--as-needed
Shared -Wl,-O1 -Wl,--as-needed
-- Configuring done
-- Generating done
-- Build files have been written to: /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build
* freecad-9999 will be built against opencascade version /usr/lib64/opencascade-7.3.0
>>> Source configured.
>>> Compiling source in /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 ...
make -j1 VERBOSE=1
/usr/bin/cmake -S/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 -B/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/CMakeFiles /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
make -f src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/depend
make[2]: Entering directory '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999 /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/DependInfo.cmake --color=
Dependee "/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/DependInfo.cmake" is newer than depender "/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/depend.internal".
Dependee "/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh/CMakeFiles/CMakeDirectoryInformation.cmake" is newer than depender "/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/depend.internal".
Scanning dependencies of target Driver
make[2]: Leaving directory '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
make -f src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build.make src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh && /usr/bin/x86_64-pc-linux-gnu-g++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -D_OCC64 -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/SMDS -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverUNV -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverDAT -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverSTL -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/StdMeshers -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/inc -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh -I/usr/lib64/oce-0.18/../../include/oce -I/usr/include/vtk-8.1 -I/usr/include/freetype2 -DNDEBUG -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -fPIC -pthread -std=gnu++11 -o CMakeFiles/Driver.dir/src/Driver/Driver_Document.cpp.o -c /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver/Driver_Document.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh && /usr/bin/x86_64-pc-linux-gnu-g++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -D_OCC64 -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/SMDS -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverUNV -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverDAT -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverSTL -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/StdMeshers -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/inc -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh -I/usr/lib64/oce-0.18/../../include/oce -I/usr/include/vtk-8.1 -I/usr/include/freetype2 -DNDEBUG -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -fPIC -pthread -std=gnu++11 -o CMakeFiles/Driver.dir/src/Driver/Driver_Mesh.cpp.o -c /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver/Driver_Mesh.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh && /usr/bin/x86_64-pc-linux-gnu-g++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -D_OCC64 -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/SMDS -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverUNV -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverDAT -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverSTL -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/StdMeshers -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/inc -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh -I/usr/lib64/oce-0.18/../../include/oce -I/usr/include/vtk-8.1 -I/usr/include/freetype2 -DNDEBUG -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -fPIC -pthread -std=gnu++11 -o CMakeFiles/Driver.dir/src/Driver/Driver_SMDS_Mesh.cpp.o -c /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver/Driver_SMDS_Mesh.cpp
[ 0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o
cd /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh && /usr/bin/x86_64-pc-linux-gnu-g++ -DCSFDB -DDriver_EXPORTS -DHAVE_CONFIG_H -DHAVE_LIMITS_H -DLIN -DOCC_CONVERT_SIGNALS -D_OCC64 -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/SMDS -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverUNV -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverDAT -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/DriverSTL -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/StdMeshers -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/inc -I/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build/src/3rdParty/salomesmesh -I/usr/lib64/oce-0.18/../../include/oce -I/usr/include/vtk-8.1 -I/usr/include/freetype2 -DNDEBUG -Wall -Wextra -Wno-write-strings -march=native -O2 -pipe -Wno-sign-compare -Wno-reorder -Wno-switch -Wno-unused-variable -Wno-unused-but-set-variable -Wno-comment -Wno-unused-parameter -Wno-empty-body -fPIC -pthread -std=gnu++11 -o CMakeFiles/Driver.dir/src/Driver/Driver_SMESHDS_Mesh.cpp.o -c /var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999/src/3rdParty/salomesmesh/src/Driver/Driver_SMESHDS_Mesh.cpp
[ 0%] Linking CXX shared library ../../../lib/libDriver.so
collect2: error: ld returned 1 exit status
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/build.make:171: lib/libDriver.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:467: src/3rdParty/salomesmesh/CMakeFiles/Driver.dir/all] Error 2
make[1]: Leaving directory '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
make: *** [Makefile:130: all] Error 2
* ERROR: media-gfx/freecad-9999::fordfrog failed (compile phase):
* emake failed
* If you need support, post the output of `emerge --info '=media-gfx/freecad-9999::fordfrog'`,
* the complete build log and the output of `emerge -pqv '=media-gfx/freecad-9999::fordfrog'`.
* The complete build log is located at '/var/tmp/portage/media-gfx/freecad-9999/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/media-gfx/freecad-9999/temp/environment'.
* Working directory: '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999_build'
* S: '/var/tmp/portage/media-gfx/freecad-9999/work/freecad-9999'
