I created a rotator to rotate an object using animation wb. Now I want to output the animation to a bunch of images to be converted to a video file. I've created the Photographer Dialog but have trouble configuring it to output images.
Something of note...
After using the Manager Dialog to create the My_Manager node in the model tree. Any attempt to select a function from the context menu (eg. About Manager, Edit, forward, backward, ping pong ) would result in error messages.
Selecting My_Manager context menu>About Manager...
File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 200, in showVersion
PySide.QtGui.QMessageBox.information(None, "About ", "Animation" + cl +" Node\nVersion " + self.vers)
AttributeError: '_ViewProviderManager' object has no attribute 'vers'
Selecting My_Manager context menu>Edit...
[['forward', <bound method _ViewProviderActor.animforward of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>], ['backward', <bound method _ViewProviderActor.animbackward of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>], ['ping pong', <bound method _ViewProviderActor.animpingpong of <Animation._ViewProviderManager object at 0x7fcadf3ff518>>]]
File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 220, in edit
self.dialog=EditWidget(self,self.emenu + anims,False)
File "/home/wt/.FreeCAD/Mod/animation/EditWidget.py", line 68, in __init__
_EditWidget.__init__(self, True, obj,menu,noclose,*args)
File "/home/wt/.FreeCAD/Mod/animation/EditWidget.py", line 31, in __init__
dial.valueChanged.connect(obj.dialer)
AttributeError: '_ViewProviderManager' object has no attribute 'dialer'
File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 256, in animforward
self.obj2.time=float(i)/100
AttributeError: '_ViewProviderManager' object has no attribute 'obj2'
Selecting My_Manager context menu>Backward...
File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 264, in animbackward
self.obj2.time=float(100-i)/100
File "/home/wt/.FreeCAD/Mod/animation/Animation.py", line 270, in animpingpong
self.animforward()
FreeCAD details
OS: Ubuntu 18.04.3 LTS (LXDE/Lubuntu)
Version: 0.19.17512 (Git) AppImage
Hash: 7b315d3a15f6c0a3e796b2bf000cb791092de079
Python version: 3.7.3
Qt version: 5.9.7
Locale: English/Canada (en_CA)
Any help greatly appreciated.
