Sezione Dinamica
mario52
Re: Sezione Dinamica
Post by mario52 »
hi
single cube, i tray now the version not modified and i cause the same problem ??? certainly my configuration ??
i have upgrade the macro in the wiki
mario
Sam
Post by Sam »
ciao mario,
I'd only tested it with some simple PDN things before I posted here. It certainly works for a simple cube for me. I should mention that I'm running a debug build. I do not know if that will make a difference.
However, I've been experimenting with more complex drawings, and the macro does actually have some more issues. For instance App.Part does not have a bounding box, so some more tweaking needs to be done.
I'll have a fool around with more over the next few days.
leoheck
Post by leoheck »
Hello, I don't understand this thread. But I came here from the Cross Section macro. It doesn't work with Freecad 0.18.3 and 0.19. There is not a window like this. When I execute it nothing happens.
renatorivo
Post by renatorivo »
leoheck wrote: Tue Aug 20, 2019 8:11 pm It doesn't work with Freecad 0.18.3 and 0.19
OS: Windows 8.1
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
g.becu
Post by g.becu »
leoheck wrote: Tue Aug 20, 2019 8:11 pm Hello, I don't understand this thread. But I came here from the Cross Section macro. It doesn't work with Freecad 0.18.3 and 0.19. There is not a window like this. When I execute it nothing happens.
Hi leoheck,
I must confess I'm new to FreeCAD, but I had the same issue and I wasn't able to find any solution googling. I managed to fix it by adding the following line:
            self.oblist = [obj for obj in self.oblist if hasattr(obj,"Shape")]
after line 334 of the code, so that you have:
	    # Make a list of the user's objects
            # WARNING!!
            # This list is persistent. We'll get confused if the user deletes or
            # adds objects while the macro is active
            self.oblist = App.ActiveDocument.Objects
            # Create the cross-section object
(macro version 0.08, the one currently available by add-on manager).
My knowledge of the FreeCAD APIs are zero but i figured out that it has something to do with the listing of the objects. In fact most of them don't have a "Shape" attribute.
OS: Linux Mint 19
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
leoheck
Post by leoheck »
@g.becu I didn't see it before. Cool, your solution fixed this issue. Thank you dude!
I need to know how to submit this to the maintainer of this macro.
mario52
Post by mario52 »
Saluti
fato Macro_cross_section grazie g.becu e benvenuto
ver 00.09 31/08/2019 : upgrade by g.becu adding line 334
mario
cadcam
Post by cadcam »
I wondered if anyone had extended this useful
macro, so that an arbitary face can be selected
and the unit normal used to define the plane of the
section?
Best Wishes
Luixx
Post by Luixx »
mario52 wrote: Sat Aug 31, 2019 10:28 am Saluti
mario
salve, mario52 protesti fare una piccola guida come si creano le macro con la gui e anche quelle senza.
perché sto leggendo la guida di onekk .. ma lui parte dai file .py, ed invece tu parti dai file ..FCMacro.
Hai qualche guida al riguardo oltre ad quella di onekk.
mario52
Post by mario52 »
salve
Luixx wrote: Fri Oct 30, 2020 4:45 pm ma lui parte dai file .py, ed invece tu parti dai file ..FCMacro.
potete rinominare .py in .FCMacro sonno tutti e due lo stesso per FreeCAD
(FCMacro e usato per distinguere una macro dedicata per FreeCAD)
ma se fate un import miofile il file "miofile" da importare deve avere l'estensione "miofile.py" sino non funziona perché diventa uno file Python
su la mia segnatura avete qualunque pagine interessante ma non tutte sono aggiornata
cadcam wrote: Fri Oct 30, 2020 8:27 am I wondered if anyone had extended this useful
more explanation or image example
(select a face and the "cut" is operate by its normal ? )
mario
