[Feature request] Clipping plane improvement
leoheck
Postby leoheck » Tue Aug 20, 2019 1:07 pm
The clipping plane tool it really good to visualize connections and debug the part or multiples parts.
The main issue I see is that it shows solid objects empty which makes it hard to inspect the part when it is complex.
I believe that some something like this, that adds a different pattern in the face where a solid is cut, would be a very good addition to Freecad.
Or even a checkbox to enable that would de good to have.
What do you think?
For comparison, right now, it shows this
Re: [Feature request] Clipping plane improvement
Postby yorik » Tue Aug 20, 2019 1:57 pm
This is harder than it looks. Coin3D is responsible for building these clipped views, and on our side, all we could do is calculate a set of section faces and add it to the scene graph. However, that would really slow things down a lot.
Coin has an extension called simvoleon, that is able to do just that, fill sections with volume. However, so far I have been able to compile it, but not make pivy recognize it or use it in any way (there is not much doc around :) )
leoheck
Postby leoheck » Tue Aug 20, 2019 2:48 pm
Interesting, I have no doubts that this is a hard task. Thanks for your comment.
A set of section faces could be an initial solution if it came with a button to enable/disable that since you are telling that it can slow the things down a lot.
Right now, the clipping plane is harder to understand than using opacity to see through the parts.
bejant
Postby bejant » Tue Aug 20, 2019 3:49 pm
This is a known problem, see issue #1208 (the ticket also links to a topic that provides some possible solutions).
leoheck
Postby leoheck » Tue Aug 20, 2019 7:22 pm
Oh, I see, and what is the status of this discussion? Do we have any recent idea being added here?
user1234
Postby user1234 » Tue Aug 20, 2019 7:29 pm
There is a macro cross section in the addon manager, but does not work on my 0.19 version.
https://www.freecadweb.org/wiki/Macro_cross_section
Greetings
user
leoheck
Postby leoheck » Tue Aug 20, 2019 8:07 pm
@user1234 it doesn't work for me 0.18.3 too. I mean, at least just executing it, If I have to edit the code so I am not using it right.
mario52
Postby mario52 » Tue Aug 20, 2019 9:48 pm
hi
no problem (Macro_cross_section)
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
OCC version: 7.2.0
OS: Windows 10 (10.0)
Version: 0.19.17651 (Git)
Hash: 16c26cb3b1cd7209ea8efc8cb30b3b18fd80cf95
Python version: 3.6.8
Qt version: 5.12.1
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
leoheck
Postby leoheck » Tue Aug 20, 2019 11:22 pm
So, the issue shouldn't be on Windows.
And what about running it in Linux?
.. Hm it is running here at my home, with the same linux and freecad version
OS: Ubuntu 19.04
Version: 0.18.3.
Python version: 3.7.3
Qt version: 5.12.2
On one model it took time to open the settings window. It was a complex model with many parts using A2Plus Workbench.
Testing it with another module that uses only the Part Design Workbench it is not loading et al. The report output is this.
  File "/home/lheck/.FreeCAD/Macro/cross_section.FCMacro", line 579, in <module>
    myWidget = CrossSectionWindow()
  File "/home/lheck/.FreeCAD/Macro/cross_section.FCMacro", line 111, in __init__
    self.child.initUI(self)
  File "/home/lheck/.FreeCAD/Macro/cross_section.FCMacro", line 149, in initUI
    self.hideObjects()
  File "/home/lheck/.FreeCAD/Macro/cross_section.FCMacro", line 365, in hideObjects
    b = self.oblist[i].Shape.BoundBox
<class 'AttributeError'>: 'App.GeoFeature' object has no attribute 'Shape'
efyx
Postby efyx » Wed Aug 21, 2019 10:49 am
This macro looks cool but I have also problem with it:
During initialization the error 'PySide2.QtGui.QPixmap.loadFromData' called with wrong argument types:
  PySide2.QtGui.QPixmap.loadFromData(str)
Supported signatures:
  PySide2.QtGui.QPixmap.loadFromData(typing.Char, int, str=None, PySide2.QtCore.Qt.ImageConversionFlags=PySide2.QtCore.Qt.ImageConversionFlag.AutoColor)
  PySide2.QtGui.QPixmap.loadFromData(PySide2.QtCore.QByteArray, str=None, PySide2.QtCore.Qt.ImageConversionFlags=PySide2.QtCore.Qt.ImageConversionFlag.AutoColor) occurred in C:\Users\Konstruktor\AppData\Roaming\FreeCAD\Mod\ShortCuts\InitGui.py
Please look into the log file for further information
  File "C:/Users/Konstruktor/AppData/Roaming/FreeCAD/Macro/cross_section.FCMacro", line 579, in <module>
  File "C:/Users/Konstruktor/AppData/Roaming/FreeCAD/Macro/cross_section.FCMacro", line 111, in __init__
  File "C:/Users/Konstruktor/AppData/Roaming/FreeCAD/Macro/cross_section.FCMacro", line 149, in initUI
    self.hideObjects()
  File "C:/Users/Konstruktor/AppData/Roaming/FreeCAD/Macro/cross_section.FCMacro", line 365, in hideObjects
on
Qt version: 5.12.1
BTW. Why not rewrite this macro and add to FreeCAD default?
