Automate Reinforcement GSoC proposal
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Postby Suraj Dadral » Tue Aug 20, 2019 6:49 pm
yorik wrote:
Tue Aug 20, 2019 2:10 pm
Hi Suraj,
Hi Yorik
As you know we need to finish this week. I am looking at your code now, your work is basically in the "automate" branch on your github repo, is that correct? I think it would be good if you could write a wrap-up explaining how to use your work, how to install, etc. I know you are busy writing docs, so probably you are doing this already.
I have completed documentation pages for new features of Rebar Addon and here are related links:
https://www.freecadweb.org/wiki/Arch_Re ... nforcement
https://www.freecadweb.org/wiki/Arch_Re ... sSixRebars
Now, I will write assumptions which we assume that user should know while creating reinforcinment with addon as suggested by @amrit3701 here:
https://forum.freecadweb.org/viewtopic. ... 70#p323817
Great work so far anyway! Congrats!
Thanks,
Suraj Dadral
Postby Suraj Dadral » Tue Aug 20, 2019 6:58 pm
amrit3701 wrote:
Tue Aug 20, 2019 4:35 pm
@Suraj,
I am trying to create reinforcement in beam by using your beam reinforcement dialog (`suraj/gsoc19-two-legged-stirrup` branch). It only creates stirrups rebars, no longitudinal rebars. Also, it throws below error in the `Report view`:
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/MainBeamReinforcement.py", line 1171, in clicked
    self.accept(button)
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/MainBeamReinforcement.py", line 1233, in accept
    self.FaceName,
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/TwoLeggedBeam.py", line 240, in makeReinforcement
    structure,
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/TwoLeggedBeam.py", line 306, in makeTopReinforcement
    facename, structure
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/Rebarfunc.py", line 701, in getFacenamesforBeamReinforcement
    return (facename_for_tb_rebars, facename_for_s_rebars)
UnboundLocalError: local variable 'facename_for_s_rebars' referenced before assignment
Hi @amrit3701, the beam reinforcement dialog seems to work fine as in documentation example:
https://www.freecadweb.org/wiki/Arch_Re ... nt#Example
I will try to investigate the error you faced and will report here.
Also, there is no image of beam reinforcement present in the dialog box. Please take a look on this issue.
I have added the image in beam reinforcement dialog box as per commit: https://github.com/SurajDadral/FreeCAD- ... c152be483e
Please check if it is fine.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Wed Aug 21, 2019 5:57 pm
Hello everyone,
Today, I discussed about the error with @amrit3701 in a video conference.
When we created reinforcement in a beam having length along x-axis, then the reinforcement created successfully.
But, when we tried to create reinforcement in a beam having length along y-axis, then it gives the same error as reported by @amrit3701.
Then @amrit3701 suggested a way to create shear rebars in beam having length along y-axis.
Now, I am implementing suggestion of @amrit3701. I will complete it by tomorrow.
Thanks,
Postby yorik » Wed Aug 21, 2019 10:12 pm
Excellent!!
Suraj Dadral
Postby Suraj Dadral » Thu Aug 22, 2019 3:39 pm
Hello everyone,
The error has been removed as per commit: https://github.com/SurajDadral/FreeCAD- ... 44760b12d5
Now, user can create beam reinforcement
- for beam having length along x-axis, by selecting right face of beam.
- for beam having length along y-axis, by selecting front face of beam.
I will modify the documentation accordingly.
Example:
import FreeCAD, Arch
from BeamReinforcement import TwoLeggedBeam
Structure = Arch.makeStructure(length=200.0,width=3000.0,height=400.0)
Structure.ViewObject.Transparency = 80
FreeCAD.ActiveDocument.recompute()
RebarGroup = TwoLeggedBeam.makeReinforcement(
    l_cover_of_stirrup=20,
    r_cover_of_stirrup=20,
    t_cover_of_stirrup=20,
    b_cover_of_stirrup=20,
    offset_of_stirrup=100,
    bent_angle=135,
    extension_factor=4,
    dia_of_stirrup=8,
    number_spacing_check=False,
    number_spacing_value=200,
    top_reinforcement_number_diameter_offset=("1#20@-60+2#16@-60+1#20@-60", "3#16@-100"),
    top_reinforcement_rebar_type="LShapeRebar",
    top_reinforcement_layer_spacing=30,
    bottom_reinforcement_number_diameter_offset=("1#20@-60+2#16@-60+1#20@-60", "3#16@-100"),
    bottom_reinforcement_rebar_type="LShapeRebar",
    bottom_reinforcement_layer_spacing=30,
    left_rebars_number_diameter_offset="1#16@-100+1#16@-100+1#16@-100",
    left_rebars_type="LShapeRebar",
    left_rebars_spacing=30,
    right_rebars_number_diameter_offset="1#16@-100+1#16@-100+1#16@-100",
    right_rebars_type="LShapeRebar",
    right_rebars_spacing=30,
    top_reinforcement_l_rebar_rounding=2,
    top_reinforcement_hook_extension=100,
    top_reinforcement_hook_orientation="Rear Outside",
    bottom_reinforcement_l_rebar_rounding=2,
    bottom_reinforcement_hook_extension=100,
    bottom_reinforcement_hook_orientation="Rear Outside",
    left_l_rebar_rounding=2,
    left_rebars_hook_extension=80,
    left_rebars_hook_orientation=("Rear Inside", "Front Inside", "Rear Inside"),
    right_l_rebar_rounding=2,
    right_rebars_hook_extension=80,
    right_rebars_hook_orientation=("Front Inside", "Rear Inside", "Front Inside"),
    structure=Structure,
    facename="Face1",
Please review and give your suggestions.
Thanks,
amrit3701
Postby amrit3701 » Sun Aug 25, 2019 10:04 am
Hi Suraj,
I have tested beam reinforcement and all previous issues are solved. :) Now, going to merge you MR.
Excellent work so far. :D
Suraj Dadral
Postby Suraj Dadral » Fri Aug 30, 2019 5:01 pm
Hi Suraj,
Thanks @Amrit
I have also modified the README.md file and here is PR: https://github.com/amrit3701/FreeCAD-Re ... nt/pull/33
Here is wrap of the work done during GSoC:
Thanks @All for your support. I will keep contributing in development of Rebar Addon.
Now, I am working on editing of Beam Reinforcement. After that I will implement master configuration for Rebar Addon.
Thanks,
ebrahim raeyat
Postby ebrahim raeyat » Sat Aug 31, 2019 2:27 pm
Hi Suraj,
Thanks @Amrit
Thanks,
Thanks @Suraj. do you have any plan for multi beam reinforcement? I mean continues beams.
and another question:
I want to produce 2d drafting for concrete structures, like in my pyconcrete github. do you think i can use your work for this goal or i must work from scratch? till now i can give some parameters from user and produce 2D beam drawing, but i want to first bring this drafting in freecad and let user to modify some parameters and then export it to dxf or dwg format.
related topic: automation if design
Thanks a lot.
bitacovir
Postby bitacovir » Sun Jan 19, 2020 1:52 pm
Is it available this automate reinforcement?
I just installed the rebar addon and these are not present in the list of options.
OS: Windows 10 (10.0)
Version: 0.19.19311 (Git)
Hash: 120b69c74f7dac8c4fa6dbc0a7e10674bde9216c
Python version: 3.6.8
Qt version: 5.12.1
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
Suraj Dadral
Postby Suraj Dadral » Sun Jan 19, 2020 1:59 pm
You can use branch "gsoc19" from repository https://github.com/amrit3701/FreeCAD-Re ... ree/gsoc19 as code is not merged in master yet.
Thanks,
