App::Link functionality should already be included in the daily AppImage:
Thanks... 0.19_pre worked great.triplus wrote: ↑Fri Aug 23, 2019 2:16 amApp::Link functionality should already be included in the daily AppImage:
Does this also mean that the possibility to install the Asm3 workbench is going to just appear in the Addons manager for the v0.19_pre binaries without any extra configuration needed from the user's part? If so, I'd be quite excited to try it out just because I'd be quite curious to learn what can be done with it!realthunder wrote: ↑Fri Aug 09, 2019 1:25 pmRight, asm3 actually works in the LinkMerge branch. I'll soon make some changes so that it can be installed through the add-on manager.
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x25d00000000) at 0x7f238934a4c8>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26000000000) at 0x7f2394862bc8>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26300000000) at 0x7f237d6bab48>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26700000000) at 0x7f238915d788>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26b00000000) at 0x7f23957b3148>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x27c00000000) at 0x7f23957b7908>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x28f00000000) at 0x7f2314074088>
no AppImage for Linux theretriplus wrote: ↑Fri Aug 23, 2019 2:16 amApp::Link functionality should already be included in the daily AppImage:
Thanks for reporting. Should have been fixed. Maybe you can try with my LinkMerge branch first.
Is your asm4 still using expression binding for placement? The upstream expression cannot call into objects. I have already prepare a PR to make it possible to do matrix multiplication just like numbers. After my bug fix PR got accepted, I'll submit the expression PR.
On master with your PR as well as with your LinkMerge branch I still get the errors:realthunder wrote: ↑Wed Aug 28, 2019 12:11 amThanks for reporting. Should have been fixed. Maybe you can try with my LinkMerge branch first.
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x1a600000000) at 0x7fef66996e10>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x27500000000) at 0x7fef65828f50>
