1. The label parameter "Display Mode" is not saved and, after opening the file, returns to "3D text"
2. Extra characters for Custom text on the working field (fixed in version 0.19)
3. When changing the "Display Mode" from "3D text" to "2D text", "Text Alignment" has to be changed several times to correctly position the inscription.
Video: https://www.freecadweb.org/tracker/file ... 5&type=bug
Incorrect behavior of the Label tool in the Draft workspace
Re: Incorrect behavior of the Label tool in the Draft workspace
Which is the FreeCAD version you are testing this with? Because reporting things against the 0.18 version isn't very helpful if it's already fixed in 0.19. The best thing to do is to test it against the latest development version. For example, Roy_043 has tested a bunch of Draft and Arch functions lately.
Draft Label: Problem with Text AlignmentRoy_043 wrote: ↑Sat Aug 17, 2019 12:03 pm I have just discovered the Frame property. Changing this to Rectangle shows that the bounding box is indeed inaccurate (assuming the frame is drawn closely around the box). For labels created from left to right, as in the OP, the frame appears to be mirrored.
Another thing I noticed: The 'Text Size' property is in fact used as the line height.
Paragraph 1 and 3 appear on all versions of FreeCAD. Last checked on this:
OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu)
Version: 0.19.17798 (Git) AppImage
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
Locale: C/Default (C)
I'll try to revisit some of the issues I have reported and add them to the bug tracker. After discussing them here first of course.
