Assembly3 preview
triplus
Re: Assembly3 preview
Postby triplus » Fri Aug 23, 2019 2:16 am
App::Link functionality should already be included in the daily AppImage:
HoWil
Postby HoWil » Fri Aug 23, 2019 11:29 am
Thanks... 0.19_pre worked great.
triplus
Postby triplus » Fri Aug 23, 2019 3:42 pm
You're welcome.
aapo
Postby aapo » Tue Aug 27, 2019 3:30 pm
realthunder wrote:
Fri Aug 09, 2019 1:25 pm
Right, asm3 actually works in the LinkMerge branch. I'll soon make some changes so that it can be installed through the add-on manager.
Does this also mean that the possibility to install the Asm3 workbench is going to just appear in the Addons manager for the v0.19_pre binaries without any extra configuration needed from the user's part? If so, I'd be quite excited to try it out just because I'd be quite curious to learn what can be done with it! :D
looo
Postby looo » Tue Aug 27, 2019 4:30 pm
I am recently trying asm3 with FreeCAD master and see some errors with qt5.12 (qt5.9 has no such issues)
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x25d00000000)  at 0x7f238934a4c8>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26000000000)  at 0x7f2394862bc8>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26300000000)  at 0x7f237d6bab48>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26700000000)  at 0x7f238915d788>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x26b00000000)  at 0x7f23957b3148>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x27c00000000)  at 0x7f23957b7908>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x28f00000000)  at 0x7f2314074088>
results in tree icons look like this:
Bildschirmfoto von 2019-08-27 18-26-38.png (13.79 KiB) Viewed 1249 times
Would be nice to solve this as appimage and dmg were changed to qt5.12 just now.
Zolko
Postby Zolko » Tue Aug 27, 2019 9:32 pm
no AppImage for Linux there :cry:
realthunder
Postby realthunder » Wed Aug 28, 2019 12:11 am
Thanks for reporting. Should have been fixed. Maybe you can try with my LinkMerge branch first.
realthunder
Postby realthunder » Wed Aug 28, 2019 1:02 am
Is your asm4 still using expression binding for placement? The upstream expression cannot call into objects. I have already prepare a PR to make it possible to do matrix multiplication just like numbers. After my bug fix PR got accepted, I'll submit the expression PR.
looo
Postby looo » Wed Aug 28, 2019 7:33 am
I made a mistake with adding solvespace to the bundles. Next build (today) hopefully solves this.
ascaron
Postby ascaron » Wed Aug 28, 2019 8:18 am
On master with your PR as well as with your LinkMerge branch I still get the errors:
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x1a600000000)  at 0x7fef66996e10>
<class 'TypeError'>: PyCXX: Error creating object of type N2Py7SeqBaseINS_4CharEEE from <PySide2.QtGui.QIcon(availableSizes[normal,Off]=(),cacheKey=0x27500000000)  at 0x7fef65828f50>
OS: Manjaro Linux (dwm/dwm)
Version: 0.19.17913 (Git)
Branch: LinkMerge
Hash: efb8502a9bc61764559bde94bb5fb57771defc6c
Python version: 3.7.4
Qt version: 5.13.0
