Feature Request: Substractive Revolution.
jruiz
Postby jruiz » Sat Aug 24, 2019 11:32 pm
Suppose a sketcth S is made on a face of certain body B , then the revolution of S, say R , is made so that R be into B.
Wouldn't it be nice to have a tool for getting the "pocket" P resulting from P = B -R?
I have uploaded some FreeCAD video tutorials to www.youtube.com/yosoyvenezolano
DeepSOIC
Re: Feature Request: Substractive Revolution.
Postby DeepSOIC » Sat Aug 24, 2019 11:34 pm
Doesn't Groove do it?
jruiz
Postby jruiz » Sat Aug 24, 2019 11:45 pm
Exactly.
For some unknown reason, groove was not working in my freecad, but now it is.
How could I delete my question?
DeepSOIC
Postby DeepSOIC » Sat Aug 24, 2019 11:51 pm
Don't worry, it will just get buried with time, rather quickly actually.
You can edit the title to insert [Solved] or something, by editing the first post.
jruiz
Postby jruiz » Sun Aug 25, 2019 12:38 am
Thanks a lot.
By the way, in the FC version I am using, groove does not appear automatically when selecting it (as it does when, for example, revolution is applied) The axis has to be (re)selected for groove to take place. Is it a micro bug?
OS: Ubuntu 18.04.3 LTS
Version: 0.18.3.
Python version: 3.6.8
Qt version: 5.9.5
DeepSOIC
Postby DeepSOIC » Sun Aug 25, 2019 12:53 am
Maybe. Please post a step-by-step guide to reproduce, then. Preferably, just a file, where one can click "Groove" and observe the lack of one.
jruiz
Postby jruiz » Sun Aug 25, 2019 1:38 am
  1. Create a body,
  2. Sketch a rectangle.
  3. Pad the sketch.
  4. Select a face of the pad make a second sketch on it: a vertical straight segment with a arc forming a "D"
  5. Place the segment on the vertical axis.
  6. Close the sketch.
  7. On task tab, select Groove.
Following these steps I get just a circle on the face of the sketch until I pres on (Axis) "Vertical sketch axis" and select any of the options, including "Vertical sketch axis", from here the groove is shown.
kisolre
Postby kisolre » Sun Aug 25, 2019 5:10 am
I had seen similar even with recent 0.19 but it was no bother because usually I just select different axis anyway and confirm.
Postby chrisb » Sun Aug 25, 2019 6:31 am
DeepSOIC asked for a file, although the step by step description is not difficult. Please consider that everyone who wants to take part in the discussion has to go through it, which is in fact a waste of time, so I attach my file here.
- load file
- select Sketch001
- click the groove icon
Here it works well, the screenshot was made directly after the click on the groove tool. Please retry with a current 0.19 version. Since new versions contain not only new things but also many bug fixes. You should always check if the bug is already removed in the current version.
Bildschirmfoto 2019-08-25 um 08.23.33.png (18.8 KiB) Viewed 267 times
OS: macOS High Sierra (10.13)
Version: 0.19.17798 (Git)
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
groove.FCStd
(8.79 KiB) Downloaded 4 times
jruiz
Postby jruiz » Sun Aug 25, 2019 3:32 pm
MIcro bug?
  1. Load grooveF.FCStd
  2. Select Sketch001
  3. On Tasks tab, click on Groove. (you'll see just a a circle, even though Vertical sketch axis is selected by default)
  4. Select an axis or press Ok and then the groove will appear.
grooveF.FCStd
(12.03 KiB) Downloaded 5 times
