Managed to find simple way to increase accuracy for small tools without affecting the performance for larger tools (and also without needing to adjust the all the parameters, the solution is based just on scaling adjustments within the alg. for tools <1mm).
i.e. before (tool 0.1mm 20% stepover, processing duration ~10 sec):
- Selection_074.png (40.73 KiB) Viewed 3359 times
after (processing duration ~ 50 sec):
- Selection_075.png (36.49 KiB) Viewed 3359 times
calculation is 5x slower in this example, but generally speaking slow-down can not be avoided as the alg. naturally needs to process/produce more points to get more accuracy.
Submitted as a PR.
BR,
K.
