S&S steam engine
un1corn
S&S steam engine
Postby un1corn » Mon Sep 02, 2019 9:33 am
Simpson and Shipton short stroke steam engine Ca 1845.
Uses horizontal rotating piston.
More info here:- https://www.pollymodelengineering.co.uk ... Engine.asp
SS 1.JPG (299.08 KiB) Viewed 2293 times
SS 3.JPG (225.45 KiB) Viewed 2293 times
SS 7.JPG (410.03 KiB) Viewed 2293 times
SS 8.JPG (231.82 KiB) Viewed 2293 times
emills2
Re: S&S steam engine
Postby emills2 » Sun Sep 08, 2019 3:35 am
This is an impressive assembly, would you be willing to share a little about your modeling strategy? Part vs PartDesign, A2, A2+, A3, those sorts of decisions you had to make along the way?
un1corn
Postby un1corn » Mon Sep 09, 2019 7:25 am
Hi emills2.
This particular model I generated a little over a year ago in FC V0.16, the greater majority of the parts were drawn in Part Design WB with the use of Part WB for Helix, cubes and cylinders, all assembled using A2.
Assembly strategies vary with the model at the time, sometimes starting from the ground up or from the middle out, components drawn in numerical order as indicated on the plans.
In some conditions Sub assemblies are useful, my only hesitation in creating subassemblies is that they do not retain the correct colours when imported into an assembly, I guess it is due to the different lighting angles of each part
I am now using V0.18 with assembly A2 plus 4.25, however, I do use the overlap facility incorporated in V0.16 A2 to check placements etc.
Thanks for asking and your comments.
mfasano
Postby mfasano » Mon Sep 09, 2019 2:54 pm
I have never heard of a horizontal rotating piston, and the link was not that informative. Is this a steam version fo the wankle engine? :?
Awsome model. I am always impressed when I visit the user showcase.
un1corn
Postby un1corn » Tue Sep 10, 2019 11:29 am
In a way I suppose it could be remotely related to Wankel engine, I admit I had not thought about it those terms.
Postby chrisb » Tue Sep 10, 2019 2:24 pm
Reading about the sealing issues reminded me immediately of the Wankel engine. Wankel wasn't really an engine specialist, he was a sealing specialist.
-alex-
Postby -alex- » Tue Sep 10, 2019 3:54 pm
Very nice assembly, as usual 8-)
Thanks for sharing
triplus
Postby triplus » Wed Sep 11, 2019 11:05 am
Nice!
