Align working plane to face fails in git build
sanderboer
Postby sanderboer » Sun Sep 08, 2019 9:20 pm
I built today's git tree and this happens when I want to align the working plane to a face :
Running the Python command 'Draft_SelectPlane' failed:
  File "/opt/freecad-190908/Mod/Draft/DraftSelectPlane.py", line 78, in Activated
    if self.handle():
  File "/opt/freecad-190908/Mod/Draft/DraftSelectPlane.py", line 242, in handle
    FreeCAD.DraftWorkingPlane.alignToFace(sel.SubObjects[0], self.taskd.form.fieldOffset.Value)
'Draft_SelectPlane' object has no attribute 'taskd'
self.handle() is called before self.taskd is declared in Activated()
vocx
Re: Align working plane to face fails in git build
Postby vocx » Sun Sep 08, 2019 9:39 pm
This definitely seems like a bug. Recently Yorik moved the Draft SelectPlane code outside the DraftTools.py file, and into its own file. He also placed the graphical interface in a TaskSelectPlane.ui file, instead of hard coding this in DraftGui.py. Maybe he missed a few things.
Give it a few days for him to fix it.
Postby bernd » Mon Sep 09, 2019 4:54 am
sanderboer
Postby sanderboer » Mon Sep 09, 2019 8:36 am
I figured it out,
Cmake does not copy the Resources dir in /src/Mod/Draft/Resources over to the installed directory.
If you do it by hand, the align to face works.
sanderboer
Postby sanderboer » Mon Sep 09, 2019 1:08 pm
Of course I thought wrong. I tested my August 4th build, this is before the change in ui organisation. However, I cannot grep fieldOffset in Draft_rc.py, seems like something qt-y went wrong in compiling Draft_rc, I think..
hvfrancesco
Postby hvfrancesco » Tue Sep 24, 2019 8:51 am
A small temporary workaround in the attached patch. not sure it's the right approach to it, but it's usable
DraftSelectPlane.patch.txt
(2.23 KiB) Downloaded 17 times
hvfrancesco
Postby hvfrancesco » Tue Sep 24, 2019 9:38 am
This is a slightly better patch, that works with 3 points plane selection too and preserves the optional offset. It's still probably just a workaround because I suppose Yorik had not finished yet the refactoring, but it seems to work
(3.85 KiB) Downloaded 13 times
Roy_043
Postby Roy_043 » Tue Sep 24, 2019 11:23 am
@hvfrancesco:
Can you post the DraftSelectPlane.py file with your modifications? It would be very helpful as this bug is quite problematic for most Arch/BIM workflows.
hvfrancesco
Postby hvfrancesco » Tue Sep 24, 2019 1:34 pm
Sure, here it is. Let me know if it works for you.
DraftSelectPlane.py.txt
(20.59 KiB) Downloaded 22 times
Postby bernd » Tue Sep 24, 2019 4:02 pm
if it fixes the problem, it would be good to go for a PR on https://github.com/FreeCAD/FreeCAD/pulls
