Help with solvers (Nastran)
I_failed_Cpp
Postby I_failed_Cpp » Tue Sep 10, 2019 5:55 pm
I've read the wiki and it seems to indicate that other solvers can be used other than those that come with FreeCAD but I can't figure out how to do that. I'm trying to get the NASA-JPL NASTRAN to run because I have need to do a DDAM analysis. What would that workflow be like? Any help on this appreciated. Also has anyone here gotten pyNastran to work? Apparently someone ported the nastran code to python but I'm not having success getting it to work but I suspect the python port would be easier to get to work within FreeCAD.
Thanks,
Bill
Reason: Added "(Nastran)" to title thread
Re: Help with solvers
Postby bernd » Tue Sep 10, 2019 6:54 pm
Before a new solver runs with FreeCAD FEM the new solver needs to be implemented in FreeCAD FEM. As an example have a look at the implementation of oofem solver in FreeCAD FEM.
https://github.com/berndhahnebach/FreeC ... s/femoofem
Postby bernd » Wed Sep 11, 2019 5:58 am
mainly what FreeCAD FEM does:
- writes an solver input file
- executes the solver
- reads the results
The biggest part is the input file. Since every solver has its own input file format this usually needs to be implemented.
saso
Postby saso » Wed Sep 11, 2019 1:11 pm
As I understand https://github.com/SteveDoyle2/pyNastran is only about reading and writing the input and output files for Nastran, so you still need the actual solver. While there seems to be some work going on on the open source code of the Nastran https://github.com/SteveDoyle2/NASTRAN-95 I don't think it is actually working, so at least for now, as I understand, one still needs an commercial Nastran solver for this to work.
johnwang
Postby johnwang » Fri May 01, 2020 11:26 am
Just saw this. Download the 95 version and tried to compile it. 2 errors now.
johnwang
Re: Help with solvers (Nastran)
Postby johnwang » Fri May 01, 2020 11:36 am
ln is not a DOS command.
LN=ln -s
ln -s
What's $^ means in Shell command? How can I do it under DOS? I may not need to make this target under DOS.
NASINFO: rf/NASINFO
	$(LN) $^ $@
saso
Postby saso » Fri May 01, 2020 11:57 am
As for the solver, it might be good to review the different forks if someone has done some more work on it (I haven't looked at it for some time)...
https://github.com/OdonataResearchLLC/N ... rk/members
maybe some interesting work to review further after a quick look at the forks
https://github.com/nasa/NASTRAN-95
--- https://github.com/AeroDME/NASTRAN-95
--- https://github.com/OdonataResearchLLC/NASTRAN-95
--- --- https://github.com/SteveDoyle2/NASTRAN-95
--- https://github.com/Open-Cascade-SAS/NASTRAN-95 <- Open Cascade !?
--- https://github.com/twuerfl/NASTRAN-95
--- --- https://github.com/ldallolio/NASTRAN-95
--- --- --- https://github.com/Atamisk/NASTRAN-95
--- --- --- https://github.com/dad98253/NASTRAN-95
Here one can find also some manuals that might come useful at some point :)
https://github.com/SteveDoyle2/NASTRAN- ... /reference
also the pyNastran documentation https://pynastran-git.readthedocs.io/en/latest/
also https://www.mystran.com/ which was developed independently but in general supports the NASTRAN format (similar to CalculiX for Abaqus)
https://github.com/dr-bill-c/MYSTRAN
--- https://github.com/Open-Cascade-SAS/MYSTRAN
saso
Postby saso » Fri May 01, 2020 12:01 pm
What's this mean? How can I do it under DOS?
mklink ?
https://www.computerhope.com/unix/uln.htm
https://www.computerhope.com/mklink.htm
johnwang
Postby johnwang » Fri May 01, 2020 12:50 pm
Just built a few Targets.
nastplot seems working. Is there any test case to plot? Never used nastran. Have no idea.
These two Targets nasthelp & jobs not built yet. Thought they are just files. Maybe could build under Linux and then copied into DOS.
johnwang
Postby johnwang » Mon Jun 29, 2020 3:57 am
um folder means user manual.
